Question about Stoves Kitchen Ranges
Frididaire 24 inch range cmef212es
Fuse size
Fuses are missing in my 1996 Tahoe LT trying to look at a diagram of the panel to see what size fuses I need, Im missing 2, 21, 22?
Which fuse box. Also not all fuse cavities will have fuses in them, there is just one fuse box for all models.
Sep 19, 2017 | Cars & Trucks
What size battery for a 1998 dodge dakota v6 pick up truck
Size 24 or 27. I found this on the AutoZone website. You can too.
Sep 26, 2014 | 1998 Dodge Dakota
What is size of freezer that is 64" tall X 33" wide x 24" deep?
64 inches times 33 inches times 24 inches is 50688 cubic inches.
One foot is 12 inches, so one cubic foot is 12 inches times 12 inches times 12 inches or 1728 cubic inches.
50688 cubic inches divided by 1728 cubic inches per cubic foot is about 29.3 cubic feet.
Apr 25, 2014 | Office Equipment & Supplies
What size is model 54160 refridgerator
The quickest way would be to measure the Volume inside of the unit. Height, Width and Depth. Example: Height 60 inches, width 24 inches, depth 24 inches then divide by 1728(Cubic inches in a Cubic foot 12x12x12). 24x24x60 = 34560 / 1728 = 20 cubic feet
Jan 08, 2014 | Kenmore Refrigerators
In which size surgical gloves are made?
Surgical gloves sizes range from 6 inches to 8 inches in increment of 0.5 inches. The variety of size options are made in order to ensure the best fitting gloves.
Feb 06, 2013 | Clothing Accessories
Could you help on the installation of a frididaire electric range? we are having some problems cant figure out why? 2nd range we bring home and the problem is the same. With the 3 wire connection we can't...
8ce06d2.jpgThese are the configurations for four wire connectors. You need to identify which one you have, then check the voltage according to the diagram. More than likley, you will need to rewire with proper wire from fuse/breaker box. If one voltage is missing it could be a blown fuse on one pole but it sounds like it was never wired for four wire. Photo couortesy of Ugly's
Jul 25, 2009 | Frigidaire FEF336BC Electric Kitchen Range
24" DOA Soyo Monitor
What size monitor were you using before? If you were using a smaller monitor and everything was fine maybe this new monitor is out of range for the graphics card. I've found that not all graphics cards, especially older ones, will not run a monitor as large as 24 inches. If you can, connect this new 24 inch monitor to a computer with a more powerful graphics card. If it works then you will know that the problem is with your computer. Also connect your old monitor and go into control panel and see what range and resolution your graphics card will support. You may need a more powerful card to run the new monitor.
Jan 11, 2009 | Soyo Computers & Internet
Kitchen Ranges Logo
Top Stoves Kitchen Ranges Experts
paulcarew
Ismael Rodriguez...
wayne murphy
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
