Question about Dewalt 3" X 21" Belt Sander
Overheating palm sander - Dewalt 3" X 21" Belt Sander
Where to apply grease
There are no parts in your sander to grease. The only place there is grease is in the three sealed bearings on the armature and in the platen. Everything should be clean and dry inside the sander to make it less likely for sawdust to stick inside the tool. Blow everything out and replace the bearings if they are not turning freely and smoothly.
Dec 01, 2012 | Dewalt D26441 - Palm Sander, 1/4 Sheet
Parts for makita palm sander BO5010
Replacement parts can be found easily on amazon, click here Amazon com makita palm sander parts and take a look. Best of luck. Fred
Aug 26, 2012 | Makita Tools & Hardware - Others
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
How to take apart the Makita 1/4 palm sander in order to replace the electrical cord? I have removed the four screws in the plastic part but it seems to have a snap section that isn't releasing. It...
you have to remove the platen on the bottom also, go to makitausa.com and you can download a parts explostion for this tool to see what I am talking about. If I have helped you would you please vote accordingly and thank you
Sep 08, 2011 | Makita Bo4556k Palm Grip Finishing Sander...
Hook sand paper will not stay on the disk of the 5" palm sander
The backing pad does not last very long on these hook and loop designed sanders, and the pad should be replaced when the edges of the pad look worn. If the edges are okay try taking a toothbrush and some degreaser (IPA or brake cleaner). Look for the replacment backing pads online or at a hardware store.
Feb 21, 2011 | Porter Cable Palm Grip R.O.S. With Kit Box...
Where can I get instsructions for the Dewalt DW411 Palm grip sander and also what type of sand paper do I get to fit it.
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
Oct 05, 2010 | Dewalt DW411 quarter - sheet palm grip...
Palm sander 6016... i have to replace the
you dont need a puller for the fan, remove the lower pad assembly and the torx screw holding the bearing in place. use a screwdriver to gently lift the fan. the bottom of tool has to be disassembled to open the halves. Go to Milwaukeetools.com and type in your model number under the download section for a parts/tool explosion. Let me know if you need more assistance
Aug 25, 2010 | Milwaukee Tool Milwaukee 1/4 Sheet Orbital...
I can't find parts for a Craftsman 5" Orbital Palm Sander
a band aid fix, if the hook and loop is wore out, but the pad is ok, is to get a peel and stick hook and loop pad that you can stick on the pad
Jul 22, 2009 | Tools & Hardware - Others
My Bosch PSM 80 palm sander on/off switch is very stiff, can it be lubricated? I so what with?
You can try and blowing it out with compressed air but I dont think that I would try any lubrication, however if you decide to I would use WD-40
Dec 16, 2008 | Bosch Power Tools Sanders Orbital Sanders
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Dewalt 3" X 21" Belt Sander Logo
Top Dewalt Tools & Hardware - Others Experts
John Trevino
john h
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
