Question about Kyocera Mita FS-3820N Laser Printer
Load mp tray comm. #9 is on display - Kyocera Mita FS-3820N Laser Printer
My Kyocera Ecosis FS4100DN keeps saying add paper in MP tray. I am only finding one paper tray that is in the front of the printer, what am I missing?
mp tray folds down right below the toner cartridge cover its looking for a size paper you don't have loaded in cassette therefore its asking you to load that size in mp tray
Sep 07, 2017 | Kyocera Office Equipment & Supplies
Red light flashes, screen says "load correct paper: A4." The paper is alreay loaded. I cannot print.
When <LOAD CORRECT PAPER> appears on the display, the size of the paper in the paper cassette or multipurpose tray is different from that of the paper specified in <PAPER SIZE> for <CASSETTE> or <MP TRAY>. You need to load the correct size paper or change the paper size in <PAPER SIZE> for <CASSETTE> or <MP TRAY>.
Check if the size of paper loaded in the paper cassette or multi-purpose tray meets the paper setting specified in the machine.
check the following:
1. The paper size specified on the printer driver screen
2. Paper loaded in the machine
3. The paper size set in <PAPER SIZE> for <CASSETTE> or <MP TRAY>
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Jan 16, 2013 | Canon ImageCLASS D1120 All-In-One Laser...
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
My OKI C5500 will only print from the MP tray, and will not take paper from the bottom paper tray, even though there is plenty of paper in the bottom tray. Its giving me a 490 Error message, but I do NOT...
490 error means -
LOAD mmm AND PRESS ONLINE SWITCH 490: MP TRAY EMPTY
Print job from MP Tray has been received and the MP Tray is empty.
Load the requested media (mmm) in the MP Tray and press ON-LINE.
Check your print driver settings and see if your defualt try is set for the MP Tray. Also see if the page setup for the print job is set for MP tray.
Feb 17, 2010 | OKI C5500n Printer
I have a brother MFC-9440cn printer. The printer is telling me to load paper in the MP load. I need to use the tray instead of the MP load. How do I go about doing this?
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Jan 14, 2010 | Brother MFC-9440CN Laser Printer
How do you access bypass tray?
The bypass tray is refered to as the multi-purpose (MP) tray. It is located vertically on top at the back of the fax machine. The fax needs to be programmed (told what size of paper is loaded) by opening the One-Touch Speed Dialing panel, press the 'Data Registration' button, press 'Set' button, then using up or down arrows to select " 5.PRINTER SETTINGS ". Press 'Set' button, then press down arrow to display " 2.PAPER SIZE ". Press 'Set', use arrow s to select CASSETTE or MP TRAY. Use arrows to select appropriate size of paper loaded. Press 'Set'. Press 'Stop' button to return to standby mode. Reference pages 15-11 and 15-12 in LC 2050 Users Guide.
Dec 17, 2009 | Canon LaserClass 2050 Plain Paper Fax
Tray selection issue: Documents may be setup to print to the MP feeder, (multipurpose feed, not manual feed), but the printer will only pull from tray 4. I'm not sure why, earlier this week it would o
The usual reason that the printer will ask you to load paper into the MPF is that the green paper guides in the paper tray is not clicked in the right position. It only needs to be slightly out of position to give the wrong paper size info to the printer. The easiest way to confirm if the guides are correct is to print the Menu Settings Page. Check that the paper sizes listed in that report are the same as the actual paper sizes in each tray. If it's different you need to adjust the guide correctly. It's remotely possible that the sensing switch is faulty but it's more likely that the paper tray guide isn't latched in it's correct position.
May 29, 2009 | IBM Infoprint 1532 Laser Printer
Hp laserjet4 printer will not print labels or envelopes
MP LOAD,
PC LOAD, or
LC LOAD
paper size,or
envelope size
The printer received a request for a paper or
envelope size not available in the printer.
MP LOAD: Load MP Tray with the requested
media. If the size is not selected in the printer
control panel, use the [MP[Paper[Size] key to enter
the requested size, or press [Shift] + [Continue] to
draw the requested size from another source, if
available.
Note: If MP LOAD remains in the display, you may
have to clear the buffer by resetting the printer.
Press [Shift] + [Reset].
Feb 12, 2009 | HP LaserJet 4 plus Printer
" Load MP Tray Letter"
Pull down the MP tray and load paper into it.
Jan 05, 2009 | Office Equipment & Supplies
IBM infoprint 1422 won't feed through paper tray, only works with mp loader
Ok.... I have these printers at work...and i think i have figured this one out :
Under setup menu , goto configure mp , then switch the settings from cassette to manual. You see these printers are used at Hotels where the bottom tray is for legal size paper used to make key packets and the mp is used for regular sized paper printing reciepts....Hilton family hotels use them for example....the next thing I'm trying to figure out is how to set it so I won't have to push the go button every time I print something
Oct 22, 2008 | IBM Infoprint 1422 Laser Printer
Kyocera Mita FS-3820N Laser Printer Logo
60 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
