Question about Dolmar Air Filter Nylon Ps 460 500 510 4600 5000 5100 - DM 181173010
Dolmar ps 500 starting - Dolmar Air Filter Nylon Ps 460 500 510 4600 5000 5100 - DM 181173010
Dolmar Model PS 6800i. Has gas and spark. pull and pull no start if I take off the air cleaner a little gas directly in the carb it will start after a few pulls. Not all thinking may be accident Help
Definitely a carburetor problem. try and clean the fuel jet. Could be dirt in it. If there is a gas filter change that as it could be plugged. Does it have a fuel bowl? If so remove it and clean it real good also.
Mar 24, 2017 | Garden
I require the complete starting assembly for a Sach DolmAR CHAINSAW, mODEL 116SI
go e-bay and search for-- recoil starters for small engines
or
recoil starter for dolmar chainsaw
Nov 26, 2016 | Garden
Coil for sachs dolmar model 120 chain saw
Ignition Module Coil for Dolmar Maybe for your Country otherwise search by Makita also there are several equvalent parts to get forSachs Dolmar and its cheaper , beware on this to order ignition coils by mention on the serial motor number and the year of build by all orderings if it must be the right combination to get it can be important by marketing technical upgrades / modifications because of changed flywheels in several Dolmar models over past time i know. a suggested coil in a link
Oct 29, 2016 | Garden
Dolmar ps 34 or makita dcs34
Replace the spark plug and get some starter fluid. Add FRESH gas/oil mix. Spray a couple squirts in the spark plug hole, replace the spark plug and try to start it. I would add Sea Foam (get it at any parts store) to the gas tank and let it run for ten minutes. Go to the manufacturers website, support, and search for your saw by model/serial number.
Mar 15, 2014 | Garden
How do you test a ignition coil on dolmar ps-3410
Replace the coil I have found this is the problem most of the time
but first disconnect the kill switch wire from the coil to make sure the switch is not shorted out
Jan 22, 2014 | Dolmar New Chainsaw PS-3410 TH TLC
My ps 9010 dolmar goes dead after about 10 minutes of running
Tim:
The problem with your saw could be a few things. First, check the filter at the end of the fuel line in the tank. Sometimes the filter hangs up in a part of the tank where it is not totally submerged in the fuel. This can happen especially if you are doing side-cuts or tilting the saw. you may possibly need to adjust the fuel/air adjustment screws on the carburetor.
Jan 18, 2013 | Dolmar New Chainsaw PS-9010
Factory carb settings for dolmar ps460 chainsaw
Try squirting a little starting fluid into the carb and try to start. If it will try to run, you have a fuel problem. Try changing the fuel filter first.
Apr 07, 2012 | Garden
I have a Makita 520i, it won't start and the local repair shop willnot work on it as they say parts are not available. Where can I get it fixed? I live in Colorado
Makita (blue) is the parent company and made by Dolmar (red). Your Makita 520i is a Dolmar 111i. That may open a few avenues for parts.
Dolmar Dealer Locator
http://www.dolmarpowerproducts.com/contact/dealer_locator/
Makita Service Centers
http://www.makita.com/en-us/Modules/Home/Default.aspx
ArboristSite.com Chainsaw thread
http://www.arboristsite.com/forumdisplay.php?f=9
This is a collection of chainsaw enthusiasts, dealers, nuts, etc. I did a search for your saw and got many hits (guess where I learned your saw is a Dolmar 111i, cutinscott I think was born a Dolmar dealer.). It is free to join and they are a pretty good bunch. HTH
Lou
These guys will even help you figure out exactly what is wrong and give advice on how to repair it.
Sep 29, 2009 | Garden
Parts manual for dolmar chainsaw made in 1987. I beleave it is modle ps7900.
I went to the dealer of the chainsaw and asked for the manual.
Sep 18, 2008 | Garden
Dolmar Air Filter Nylon Ps 460 500 510 4600 5000 5100 - DM 181173010 Logo
19 people viewed this question
Top Dolmar Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Dolmar Garden Expert? Answer questions, earn points and help others
