Question about Energizer Rechargable Battery with Charger
Energizer CHDC charger suddenly not indicating if charging or not
Hi, I have a Energizer CHDC-CA charger, and I was charging just a minute ago..... But now the light won't turn on, leaving me in confusion if it was charging or not.... Solutions will be greatly appreciated. The battery is Energizer Rechargeable 2500 mAh. Yes, it is nickel-metal hydride(NiMH).
  • Anonymous Mar 30, 2014
    I have an Energizer battery charger that can charge both AA and AAA (2 slots each). It says in the instruction manual that it takes about 18 hours to charge 2000 mAh nickel-metal hydride batteries, and that when the batteries are fully charged, the light shuts off. It has been a lot more than 18 hours (probably three or four times more), and the green light is still on. Does this mean my charger is broken? (Just bough it brand new too) Or something else?
    I have an Energizer NIMH battery charger that can charge both AA and AAA (2 slots each). It says in the instruction manual that it takes about 18 hours to charge 2000 mAh nickel-metal hydride batteries, and that when the batteries are fully charged, the light shuts off. It has been a lot more than 18 hours (probably three or four times more than 18 hours), and the green light is still on. Does this mean my charger is broken? (Just bough it brand new too) Or something else?
    Problem Solver:
  • 8 Answers
It sounds like the PC Board which provides the circuitry for the Charger's indicating light is malfuntioning. If you have a DC volt-meter, you can check the Charger's output voltage, and then the Battery voltage to determine if your charger is functioning.
Hint: If the Charger has an output voltage, but the Battery's voltage is less than its rated voltage... it's time for a new battery.
Posted on Mar 23, 2009
Iam using Energizer 15min charger. I have used for a longer time. Now the charger red light blinks while trying to re-charge batteries. I have tried various batteries but red light blinks. Failed to charge...
A flashing light indicates that the charger seems to detect a problem with the cells. (two or more cells form a battery). Since you've tried other cells, it can be reasonably assumed that the charger is faulty and should be replaced.
Feb 14, 2011 | Energizer 15 Minute Battery Charger Combo...
Energizer CH2PC-UK battery charger' how long do i charge AA and AAA batteries
Charge time depends on the mAh capacity of the batteries (should be listed on the package, or the side of the battery) most AAAs are under 900mAh so 2 hrs should be sufficient, but AAs vary greatly in capacity so heres a link to check after you look up your mAh rating
http://energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Jan 14, 2011 | Energizer Rechargable Battery with Charger
15 min energizer charger cuts off after 5 seconds
Plug it into mains without battery.
Put the battery(s) into place. If batteries OK (but need charging) it will begin charging. If batteries very low it will cut off. If batteries charged it will charge only 1 - 10s.
Jun 07, 2010 | Energizer 15 Minute Battery Charger Combo...
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
The LED's on my Energizer charger flash red and green constantly.
If your charging 2 batteries only they must be palced in the following poistions on the charger
1. both side by side in the 2 left slots
or
2. one each in the two right slots.
Otherwise the batteries will not charge.
The users manual can be downloaded here:
http://www.energizer.com/SiteCollectionDocuments/pdf/rechargeable/CHDC.pdf
Thanks for using FixYa.
Kelly
If the batteries are charging the battery indicators
Mar 24, 2010 | Energizer Rechargable Battery with Charger
Energizer 15 minute Ni-MH Battery charger
A flashing red light indicates that there's an error, or the batteries are defective.
No, the unit won't switch itself off once the batteries have been fully charged. The unit will start trickle charging instead.
Dec 24, 2008 | Energizer 15 Minute Battery Charger Combo...
Energizer Rechargable Battery with Charger Logo
1,205 people viewed this question
Top Energizer Electronics - Others Experts
cwradio73
Are you an Energizer Electronics - Other Expert? Answer questions, earn points and help others
