Question about Hobart H600 Stand Mixer
Oil change for hobart d340 mixer - Hobart H600 Stand Mixer
bigg t
  • 640 Answers
SOURCE: Hobart 140 Qt Mixer 4 speed. needs the oil changed? what kind of oil to use?
You can use a heavy weight gear oil or call the local hobart branch for it.To remove oil----Look under the mixer where the beater shaft is in the back and you will see a three quarter inch nut,remove this nut and drain the oil then put nut back in.To fill the unit remove the top cover screws and remove the top,you will see a long hexagon nut in length,remove this and grab a funnel then add the oil---be patient it takes time to fill as the oil is heavy.
Posted on Jul 26, 2008
bigg t
  • 640 Answers
SOURCE: I need to change gear oil in Hobart H600 mixer.
Take the top cover off,where the front screw on the cover goes in that long shft has to be unscrewed,get a funnel and add oil.
Posted on Feb 20, 2009
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
milten1
  • 1304 Answers
SOURCE: how do you change the oil in a hobart h 600-dt
there is an oil case drain pulg under the top by the clutch, you can drain the motor housing through there, \
i have used 5w30 in a pinch
but it would be better if you ordered hobart oil from the website
its cheap but very very good
Posted on Oct 16, 2009
  • 110 Answers
SOURCE: PLEASE HOW TO CHANGE OIL OF A HOBART MIXER
underneath trans. you will find a drain plug remove, drain oil,replace plug ck the sight glass @ this time if not clear would recommend replacing glass remove top cover where the front cover screw theaded into remove that is your fill hole. add new oil till you hit level line in sight glass,reassemble
Posted on Jan 09, 2010
D340 Mixer Paddle slipping
if the paddle is slipping while the agitator shaft is turning then you may have a problem with the agitator pin shaft it is either gone or not engaged
May 18, 2010 | Hobart D340-6007 Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
The dough hook wont cone off.
Got a hold of Hobart company and resolved the problem.
Jan 06, 2010 | Hobart D340-6009 Mixer
Hobart mixer making grinding noise
the noise is not a good sign. would rec. taking apart trans. and investigate gears,shafts, before futher damage takes place
Nov 30, 2009 | Hobart D340-6009 Mixer
Wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Oct 08, 2009 | Hobart D340-6009 Mixer
This is a 3 phase mixer. Is it possible to connect it to my single phase bakery without buying a 3 phase converter?
no not without changing mtr. contactors,installing a roto-phaseinverter is the way to go dont get static inverter
Aug 27, 2009 | Hobart D340-6007 Mixer
Where can I get a manuel for my hobart D-340 mixer?
What kind of manual do you need. The service manuals are only given to Hobart technicians while they are attending training classes for that paticular piece of equip. I have a parts manual w/ exploded views if needed. A operators manual/guide can be downloaded from Hobarts website. You will need Model, Serial & ML # or spec #.
Jul 09, 2009 | Hobart D340-6007 Mixer
We have an old hobart mixer,when we turn it on it won't go into gear,,can't get any gear to work
you do not say what model mixer you have but more than likely the shifter yoke is faulty
Jan 04, 2009 | Hobart D340-6007 Mixer
Hobart L-800 Mixer is rotating in the wrong direction
Doesnt matter,just switch any 2 power wires.
Aug 29, 2008 | Hobart D340-6007 Mixer
Hobart 60 quart mixer
the motor protection board is doing its job.you should only use 1st speed to mix pizza dough.im a hobart technician and service these mixers all the time.let me know
Jan 27, 2008 | Hobart D340-6007 Mixer
Hobart H600 Stand Mixer Logo
91 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
