Question about LG 32LD460 MULTISYSTEM FUHD LCD TV FOR 110-240 VOLTS
K13a60d blow off power supply card of 32ld460
In lg 32ld460 in supply board. K13a60d blow off and tow rasistenses value .012e. Heat up
3 Suggested Answers
  • 5 Answers
SOURCE: LG 23LC1RB TV Capacitor blown on
try this link
capacitors.best-price.com
hope this helps?
Posted on Mar 11, 2011
gopakumarg43
  • 75581 Answers
SOURCE: LG 47LB5DF bad part
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Try it, and see whether it help you or not.
Posted on Feb 26, 2014
I NEED THE DIAGRAM FOR LG 32LD460-AFB POWER SUPPLY BOARD
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Circuit diagrams of SMPS section of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 06, 2016 | LG Televison & Video
47" lg tv turns on then back off
Check the power supply board first. All voltages have to be present and within 10% of the value printed on the board.
Sep 26, 2015 | LG Televison & Video
Shorted q18
check value of caps in power supply they tend to dry out. do to heat.
Feb 23, 2014 | LG 50PC3D 50 in. Plasma Television
Lg 42'' plasma, getting audio but the panel is not
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
often that *needs* to be done in a service center as there are some adjustments to be made after replacement.
Hoping this will help in solving the problem.....
Aug 05, 2011 | LG Televison & Video
My 50 inch lg plasma tv is flickering with no picture, we were watching it an u heard a click and then flickers with no picture.
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.If otherwise,The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Take care in solving the problem....
May 26, 2011 | LG Televison & Video
We bought a new LG 32LD460 tv this morning. It switched on fine and we had it running with good picture and all. Then we left it for a while and came back to try and set up the xbox. It switched on with...
It sounds like a powere supply problem. You will need to take the back off and test the voltages that are printed on the power pcb with a digital multimeter. Need to check the power button light, if it is on then you have the 5VDC standby power and the issue might be the main board. I will do further research on this problem.
Apr 03, 2011 | LG 32LD450 32 In. LCD HDTV
Lg flatron plasma screen tv keeps flashing on and off
All you have to do is to open the back cover of the television to check for bulged capacitors, if found replaced with the same value, but if otherwise Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Good luck , hope this helpout
Aug 02, 2010 | LG Televison & Video
Roland KC-550 blows 500ma fuses in power supply for no appearent reason. Why does this happen and are fuses correct value?
Fuses blow when there is an overload. This is caused by a faulty part in either the power supply (such as transformer or any semi-conductor -diodes, rectifier, IC, transistors etc) or in the main amp stage - anything on the heat sink. The most common cause is a semi-conductor acting like it was just a piece of wire. A cause of an overload alsot is a speaker wire shorting, which blows out the transistors on the heat sink or whatever is on there, they in turn blow the fuse!
Whatever value fuses is put in will blow! The higher the rating however could cause something to get hot thus causing a fire, before they do go!
If the 500ma fuses where the originals marked on the end cap, then stick with them. Often it is writtten on the PC board too.
May 20, 2010 | Audio Players & Recorders
LG 32LD460 MULTISYSTEM FUHD LCD TV FOR 110-240 VOLTS Logo
73 people viewed this question
