Question about Sport & Outdoor - Others
How to remove mechanism cover from aqua-magic iv
Bowl turns on our thetford Aqua Magic Style ll rv toilet
the reason you are getting sewer gases are the wax seal under the toilet is not making proper contact with the bowl and flange....pull the toilet and replace the wax seal...buy a cant leak seal from lowes...may want to buy new bolts to reinstall...they sell plastic ones that you can cut easy after you tighten...make sure to shim the toilet if it moves...use toilet shims...also at lowes...this is why this happened to start with...it was not done right to start ...after all that caulk or grout bowl to floor...now you have a pro install...
Jun 18, 2014 | Thetford 42058 Aqua Magic Style II High...
Aquabrass tub drain control lever cover separated from nut
lock tight red or stronger will bond it together . but forget remove it after
Nov 16, 2013 | Aqua Brass Deckmount 5 pc tub set with...
Iv got Shimano Alivio 9speed shifters. My front derailleur cable is damaged so im attempting to replace it. Iv detached the cable from the derailleur, iv opened the front shifter covers, but I'm not...
If there is no internal routing under the covers, check the sides near the triggers. There will be a black plactic phillipes head screw. Shift the derailleur down the high gear or where all the tension is released from the line. Disconnect the cable and feed it backwards towards the shifter. the cable will come out the hole where the cable previously was inserted
Dec 30, 2012 | Cycling
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
How to fix the pedal flush on a Tetford Aqua Magic IV
I saw the other answers and what are they talking about. thetford is a rv toilet the two bottem pedals are control by cable one cable broke You just have to get pedal repair kit pull toilet out and repair I have a repair kit coming as we speak exact same problem
Apr 16, 2012 | Thetford Home
How to remove pump from motor
remove the bolts holding the suction side cover on. remove the cover on the end of the motor and use a tool (armature holding tool) to immobilize the motor shaft. remove the center screw (if applicable) in the middle of the impeller by turning clockwise. Spin the impeller off by turning counter-clockwise. If it will not come off, you may need an impeller wrench. Once the impeller is off you can remove the four through bolts and the motor should come right off.
Oct 30, 2010 | Aqua Flo 1 HP Aqua-Flo Pump: 1.5" in/out,...
I AM UNABLE TO GET MY WET END PART # 91040840 DISCONNECTED FROM THE MOTOR SHAFT. WHERE WOULD I FIND SCHEMATICS PERTAINING TO THIS.
you will need to remove the back cover on the motor and the suction side cover to expose the impeller. You'll need to hold the shaft from turning and remove the impeller by turning counterclockwise. Some impellers will have a phillips head screw in the center, if so, you can remove it by turning it clockwise. Once the impeller is removed, you can loosen the through bolts and it will all come apart. You can install the new seal and reverse the process to put back together. Hope this helps.
Oct 29, 2010 | Aqua Flo AQUA-FLO #200 SEAL, REPLACEMENT -...
MVP IV Microwave Model VM12AM-1
There are a series of switches in the door latch mechanism which are a safety interlock system. If the latch on the door is secure and not broken then it is in the latch mechanism itself. It is possible for the mechanism to come loose and stop the oven from working. The control panel will have to be removed and the mechanism adjusted for proper operation.
Alternately if the door hinges (screw in type) are not aligned properly then it can cause the same symptoms.
I am unable to locate your model in my reference, but there is usually one or two screws behind the grille that hold the control panel on if it is a vent hood style. If it is a cabinet style then the cabinet will have to be opened. Be sure to disconnect power at lease 1/2 hour before opening.
Jul 28, 2008 | Magic Chef Microwave Ovens
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
