Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ge tfx20jr side by side
The Ice maker in tis model that is has few years does not fill even a quarter of ice maker compartment with ice
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Make sure your freezer freezing if freezing check water valve check icemaker
Posted on Apr 06, 2009
My GE 19.7 TFX20JR only partially freezes in certain areas and not cold on refrigerator side. This all happened at the same time it stopped making ice. Water still dispenses.
Check for frozen, iced over evaporator coil caused by defective defrost timer and/or heating element. Ice maker will not work unless freezer temp is around 10 degrees or less.
Mar 15, 2015 | GE Refrigerators
I have a ge tfx20jr side by side the ice maker is not dumping the water fills the tray but it won't dump
That is an electronic control ice maker and possibly worked hard for the last few years. If the ice maker will not respond to the full arm or switch being on to empty the cubes about the only thing you can do is replace it=> WR30X0327 Ice Maker Assembly
I am here if you have questions, John Tripp Appliance 911
Contact me here.
Jul 30, 2014 | Refrigerators
Intermittant ice making
When you see this happen can you feel the bottom of the ice maker to see if hot? What is the correct model number? I am trying to understand if it is the ice maker heating element is stuck on while heating the ice maker to release the cubes or if the water control valve is allowing the water to come in through the fill tube like a leaking faucet. Thanks, John Tripp Appliance 911
6aa070b8-d84c-4116-a3d3-21bc4d340b93.jpg PSS26MSRSS)?
Jan 27, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge tfx20jr icemaker not working
First check that ice maker is on. Check ice maker water valve and make sure freezer is freezing. Is there ice in the ice maker? If so its not harvisting replace ice maker
Aug 22, 2013 | Refrigerators
ICE MAKER QUIT WORKING ON GE 19.7 TFX20JR BUT WATER STILLS WORKS
you have a dual valve one side quit working. get a new inlet valve.
Aug 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Gss20I eph ice maker ?? If I turn the switch of
I am almost sure the model ice maker for your refrigerator is Click Here=> WR30X10093 and the model number for your refrigerator is GSS20IEPHWW or SS for Stainless. It sounds as if a bad connection on the ice fill arm. The truth is they are electronic and made in China along with most of the parts on your GE. I replaced mine that was the mechanical type with this same model number WR30X10093 and the mechanical lasted 15 years. If you manually can make it work one time and fills properly but after one cycle yet turns itself off my focus is on the ice maker. If you want to check OHM's to the dual water control valves they should both be about the same. Applying 120 volts to each side of the coils being water dispenser side and ice maker side will or should open them. But you just said that moving the arm that it will fill one time so I am back to the ice maker again. If water control valve for ice maker side did not work you would not be able to do that. Sea Breeze
May 20, 2010 | GE GSS20IEP Side by Side Refrigerator
GE side by side refrigerator. Ice maker has a
remove and clear ice. if it happens again change water valve it might be leaking
Feb 12, 2010 | Refrigerators
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE TFX24F Ice maker does not stop filling
did you try pushing up the arm on the side of the ice cube tray
Jun 17, 2009 | GE Refrigerators
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
489 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
