Question about Nintendo DS Lite Black Console
How to remove stripped screw on nintendo dsl - Nintendo DS Lite Black Console
Any ideas on how to remove a stripped screw from lawn mower, Briggs and Stratton, top plate, there are 3 screws and one is stripped not allowing the cover to come off
By stripped, do you mean the head is stripped, or are the threads stripped.
Head stripped = Damaged Screw Extractor Drill Bits 4 in 1 Bolt Extractor Set Easy Out...
Stripped threads = You need to "drill off" the head of the stripped screw. Get a sharp drill bit that is at least twice the size of the threads. Drill into the screw head until the entire head is gone or can be removed..Once the entire head is gone, you should be able to remove the cover..once the cover is off, you should be able to remove the screw with vise grips or other suitable tools.
Jul 08, 2017 | Briggs Garden
Stripped screw on shark navigator plate
drill the head down to the shaft of the screw then remove plate, remove remainder of screw if possible, fit new screw.
Dec 30, 2013 | Vacuums
How to remove a stuck screw!!! I cant get any of them out!! Help!!!
You need a proper tri screw bit to remove many of the screws on the DS line. If you have stripped the screw, use a slightly bigger flat screw head and apply a lot of pressure and hope it unscrews.
Aug 25, 2013 | Nintendo DS Video Game Consoles & Games
How can I fix a Wii console that fell and will not recognize the remotes?
You will have to strip down the Wii and reseat the bluetooth dongle. It has probably popped out of its socket.
You could strip the Wii down and remove the dvd drive.
Then press down gently on the metal shield to the left of the memory card socket. You will see the dongle but you cannot get a flat probe (dinner knife) on top of the dongle as the is some padding in the way. With luck the gentle pressure will work, otherwise you will have to undo all the shield screws and the heatsink and fan housing.
Some people just take the front half a dozen screws off and bend the shielding back to get at the dongle. It depends how much you love your Wii!
Jul 24, 2010 | Nintendo Wii Console
Stripped screw needs to be removed
hello. You will probably have to drill out these screws enough to use a tool called a screw extractor. That said take a look at this excellent link http://www.ehow.com/how_2078426_remove-stripped-screw.html
Joe
May 09, 2010 | Mtd 22" Yard Machine Push Mower
DSL screen not responding
Hello :
Here I'll provide a link provided by Nintendo for touch screen problems :
Nintendo DS Lite - Touch Screen Problems
Read carefully please .
rate for the effort if useful please !
Best regards .
Mar 21, 2010 | Nintendo DS Lite Console
My mic is not working cant talk too it to play some games i have hadit just over a year
You can get replacement microphones off ebay cheaply. But you need to have good electronics skills to replace it as it involves a complete strip down of the DSL to do it.
Dec 19, 2009 | Nintendo DS Lite Console
My nintendo ds lite wont turn on because i got water in it and my
Well you were certainly thinking the thing about taking the battery out of the DS, what I would do is to try and get the screw out of the socket. And then if that doesn't work I recommend having it looked at and repaired by professionals such as "Nintendo Customer Service"(NCS).P.S. to make an appointment with NCS hold down "Ctrl" and left click on "Nintendo Customer Service".
Sep 27, 2009 | Nintendo DS Lite Black Console
2 discs stuck in console
WOW!!! I am so sorry that this happened. Nintendo products are really hard to open. If you cant wedge the game out with a small screwdriver, dont worry about the game, here are the directions on opening it. Just copy and paste to word so you can see the whole thing easily.
How to open your Wii Console Step by Step Instructions
To disassemble:
  1. Flip the device upside down and remove the small silver Phillips screw. Once out, remove the battery tray from the console.
  2. Next remove the rubber foot directly above this battery tray. Also remove the three square white stickers from the bottom of the Wii. The rubber foot and the sticker are covering hidden screws. Figure 3 provides a shot of where these screws are located. NOTE
    Hiding screws under stickers and rubber pads is a common method used by electronics manufactures to help increase the aesthetics of their devices, as well as prevent people from easily locating screws and taking apart their products.
  3. Unscrew the two Triwing screws and three Phillips screws from the bottom of the Wii.
Figure 3 - Bottom Screws
  1. Flip the Wii over onto its right side. Locate and remove the two rear rubber feet and the two rectangle stickers near the faceplate.
  2. Remove the two silver Triwing screws in the holes and remove the two black Triwing screws on the faceplate (Figure 4).
Figure 4 - Left side screw locations
  1. Flip the Wii upright and carefully remove the two socket covers. They come right out with a little wiggling.
  2. Remove the three black Phillips screws from the black plate (Figure 5). Note the one closest to the faceplate is the longest and will need to go back into that hole when putting the Wii back together.
Figure 5 - Top black plate screw locations
  1. With the screws removed, carefully pull off the faceplate of the front of the Wii. You will need to disconnect the red/black wire plug from the Wii to remove the faceplate completely. Figure 6 shows what is hiding under the faceplate.
wiifig06.jpg Figure 6 - Under the Wii faceplate
  1. Remove black plate from memory/controller socket area.
Remove two silver Phillips and two silver Triwing screws from memory/controller socket area (Figure 7). wiifig07.jpg Figure 7 - Topside screw locations
Lay the Wii on left side (with the ATI and Nintendo logo facing you) and slowly work the right side cover of the console off the device.
This will take a little bit of force. If something appears to be stuck, double check to ensure you removed all the screws.
Locate and remove four screws holding DVD reader in place. Two are located in plain site in the middle of the unit. Two are located near the front of the Wii inside the DVD unit (Figure 8). wiifig08.jpg Figure 8 - The insides of the Wii
Slowly tilt the DVD player upward toward top of Wii. There are two wires that need to be disconnected before you can safely remove the DVD unit. One is a plug type of connector that only requires a little tug. The other is a circuit strip connector that requires you to lift the brown catch, which will release the pressure holding the strip in place (Figure 9). Do not break this!
May 11, 2009 | Nintendo Wii Console
Nintendo DS Lite Black Console Logo
35 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
