Question about Sewing Machines
How too clean and repair my singer memo matic 210
Just got this knitting machine very dirty and bent needles
3 Suggested Answers
SOURCE: I have an old Singer Memo-Matic 360/260 Knitting
i just got a singer 360 knitting machine but do not have the instuctions can you let me know were i can get them
Posted on Aug 22, 2011
mchristiev
Have you tried repairing the foam bar that is under the needles?
check out uTube for directions on 'how to repair knitting machine foam bar'
Good luck.
Posted on Mar 09, 2015
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
My singer tradition 2250 won't stitch without dropping stitchs worse in zigzags or with Lycra, have tried dog foot also. Have tried altering tension makes it worse, you can hear it skipping stitches.
Have you tried a brand-new needle? Frequently, a bent, dull, or incorrect needle will cause skipped stitches.
Also, for sewing knits (lycra), be sure to use a ball-point needle. Likewise, use the appropriate needle for the thread & fabric you are sewing. Avoid using old or bargain bin threads.
All About Needles
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwjawNi-zMvMAhUY52MKHbxmBzgQFggjMAE&url=http%3A%2F%2Fwww.schmetzneedles.com%2Flearning%2Fpdf%2Fschmetz-needle-chart.pdf&usg=AFQjCNHTR52AmqwzvyCjbXmD5Ch52Va5_Q
If it continues to be a problem, you may need to have it serviced for needle/hook timing.
May 08, 2016 | Singer Sewing Machines
Singer 534 skipping stitches
Most sewing machines will sew well on sturdy woven fabrics without being perfectly adjusted. However, because knit fabrics have more stretch, and have a tendency to pull the needle in one direction or another, a sewing machine has to be very well adjusted to sew on them well. You needle clearance or timing could be slightly off, and would cause the machine to skip on knits. Unless you have a reasonable amount of experience with adjusting sewing machines, it would probably be best to take your machine to a repair shop to get it adjusted. Make sure you tell them what kind of thread and material you are working with. Take some samples if you can.
Mar 19, 2014 | Janome Sewing Machines
I have singer memo matic 360/260. I want to know how to use punch card
They are available for free here: http://knittsings.com/knitting-machine-manuals/
Oct 06, 2013 | Singer 132QRFB Mechanical Sewing Machine
What size needle does the singer merrit 8734 use
here is a free downloadable manual from singer,here's the link
http://www.singerco.com/uploads/download/672_8734-8834.pdf
in the manual in the accessories it tells about the needles,
on page 7, I believe,, general sewing singer size 2020,,
& knits, stretch, elastic size 2045
plastic bobbins
Aug 30, 2012 | Singer Merritt 8734
Im trying to fnd a manual for 321 singer memo-matic machine
The manual is available for sale (electronic copy $5) here: http://www.theknittingcloset.com/pd-knitting-machine-manuals---e-transfer-downloads.cfm . Select the 321 model in the Studio/Singer/Silver Reed/White drop box and then click Add to Shopping Cart.
The basic directions for Singer Knitting Machines are here http://www.ehow.com/how_5675461_work-singer-knitting-machine.html .
I hope this helps.
Jun 17, 2011 | Singer Sewing Machines
I have an old Singer Memo-Matic 360/260 KNITTING MACHINE. I pulled the machine apart to repair a small dent and put it back together again. The carriage works only in one direction. Can you help me?...
yes a sping must have come off tip it upside down and move the tuck slip etc lever and see that they move, you will see the course that the needles should take, take a close look and see which part of the cams move underneathe try both sides and you will find that one wont match up maybe a pring has popped off or broke good luck. oh also check the side guiders that feed the needles into the carriage, maybe one has been knocked or dented..
May 15, 2009 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
54 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
