Question about Ricoh Aficio 2022 All-In-One Laser Printer
Default admin password for ricoh 2022
Reset web password
no_pc-gst
  • 58 Answers
SOURCE: I need to reset the Key Operator Password on Ricoh 1515MF
Look about the Service Manual (for technican)
souch informations you will find there:
http://fileshare.eshop.bg/downloadsm/33807/Ricoh_1515.html
or there:
http://www.eserviceinfo.com/index.php?what=search2&searchstring=aficio+550-650
Posted on Jan 02, 2009
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
thunderbo611
  • 66 Answers
SOURCE: How to reset web password on Rihoh CL7200
factory settings
Posted on Jan 26, 2010
  • 903 Answers
SOURCE: Ricoh Aficio 2022 Error Code 872. Do I need a
sc872 is a hard drive error. Your hard drive may need to be replaced, or it might just need to be checked or formatted. You should have a service technician take a look at it.
Posted on Mar 06, 2011
nonontech
  • 4737 Answers
SOURCE: I need to know how
If I am not wrong, you are looking for information about how to reset the WIM (web interface monitor) password. Actually, the password and the username is saved in the NVRAM (Non-volatile Random Access Memory) of the machine which is a tiny computer chip pre-installed on the motherboard. There is only one option you can try instead of re-seating or replacing NVRAM. I hope you haven't tried the "supervisor" account, if not, try logging in by entering the username as "supervisor" and leave the password blank. If this works, you are saved from replacing the NVRAM and or calling a local tech to do it for you (and of course you are also saved from buying the NVRAM chip). But if in case the 'supervisor' account login details has also been changed, then you don't have another choice instead of replacing the NVRAM. I am sorry but your only option is to contact Ricoh or to call a local tech to get it done for you. It's not recommended to do it yourself since a slight mistake might damage the machine permanently and also you'll need to know which type or number of NVRAM is installed on your machine's motherboard.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Posted on May 01, 2011
You do not have the privileges to use this function
you need to log in as admin to change the settings
default admin password is blank
if you dont know the password let me know
Jun 12, 2014 | Ricoh Aficio 2022 Black and White Copier
How to reset login name and password for aficio 2075?
The default is admin and no password.
If this has been changed you can reset the admin pass by logging in as supervisor and no password.
This form might help if you are still having trouble from there.
How do reset the administrator password on the Ricoh Aficio MP C2050
Jun 04, 2014 | Ricoh Aficio Office Equipment & Supplies
How to reset login name and password for ricoh 2075
Jun 04, 2014 | Office Equipment & Supplies
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
I reset the WRT400N password, then entered the default password admin and it does not work
here is the link to the user manual ...if you changed the admin password and cannot get in you will have to reset the router and put all new settings back in
the default user name is : wrt400 or wrt400n
and default password is admin
To access the web-based utility, launch the web browser on
your computer, and enter the Router’s default IP address,
192.168.1.1 or http://wrt400n.com in the Address field.
Then, press Enter.
A password request screen will appear. (Non-Windows XP
users will see a similar screen.) Leave the User name field
blank. The first time you open the web-based utility, use
the default password admin. (You can set a new password
on the Administration > Management screen.) Click OK to
continue.
http://www.abt.com/images/products/PDF_Files/wrt400n_manual.pdf
Feb 17, 2010 | Linksys WRT400N Router
I have problem sending email from scanner. I tried to access my scanner through web, but i forgot password. How can i reset that password?
the web interface username and passwords are typically username =
and password = admin
or username is admin
password is password
Jul 24, 2009 | Ricoh Aficio SP-C210SF Printer
How to reset pass admin RICOH aficio 1224c?
The user ID is blank. The password is the word password.
If that doesn't work, let me know.
Mar 14, 2009 | Office Equipment & Supplies
Ricoh IS200e Web interface password
default login: scanner
default password: password
Jul 17, 2008 | Office Equipment & Supplies
Lost admin password for ricoh aficio 3260c.
if u have bios password u shoud do that remove your bios battry from the motherboard for few mints & your password will be reset
Jul 16, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh Aficio 2022 All-In-One Laser Printer Logo
163 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
