Question about Fishman Loudbox Mini Acoustic Amplifier Amp Acoustic
Can you better explain the Chorus function?
The manual states "controls the depth of 2 separate chorus presets" and I haven't a clue what this means? do I use this function and how so?
My yamaha psr s 700 changes sound sometimes hand with all d bottons Woking if I start d keyboard all botton will not come up util 20mins after switched off plz I really a solution cus im so tired
lots of issues there
will need taking apart to find the faults and repair
some possibles
power source input low
internal circuity faults
switches
dry solder
diode faults
internal dust build up
One of Yamaha's new arranger keyboards, the PSR-S700 is the more entry-level model, but still comes with a range of impressive features:
  • 61 touch responsive keys
  • 96 notes of polyphony
  • 5.7-inch QVGA LCD capable of lyrics and score display
  • AWM (Advanced Wave Memory) sample sounds
  • 813 preset voices made up from 317 voices, 16 drum kits, 480 XG voices
  • 10 MegaVoices
  • 11 Sweet! Voices
  • 18 Cool! Voices
  • 14 Live! Voices
  • 9 Organ Flutes
  • 2 layer voices
  • Large number of preset and user-definable effects including reverb, chorus, 4 x DSP (Digital Signal Processing)
  • 205 preset 8-part auto-accompaniment + user category with mixer controls
  • 16 track recording
  • 30,000 note capacity
  • Performance assistance technology
Sep 15, 2016 | Yamaha Music
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
Circuit board repair
You don't tell us what make and model you need help with
Apr 04, 2015 | Music
What preset effect number is best for karaoke?
Always use echo and reverb, or just reverb for inexperienced singers. If I remember right this is from effect 19 but this is a very inflexible set-up with no control over the effects, just presets. You'll need to listen and decide what is best. You may also try chorus as with a decent effects unit this can be very effective plus a bit of reverb and echo.
Different songs like different effects and we will chop and change even in a single track when live mixing professional acts.
Dec 26, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
User manual for DOD DFX9 DIGITAL DELAY GUITAR PEDAL
Can't find a manual but can still explain. Delays, chorus, flangers, and reverbs are all the same effect except the different names of them will allow you different adjustments. Chorus usually has a width control which controls pitch shifting. Flangers and delays will have a feedback control which simply means, how many times you hear the echo. On reverb units, room size means how long of echo(even though it;s short) you want. Delay is the same with much longer echo, feedback is the same as on flangers except the flangers time is very short meaning the effect is at almost the exact time resulting in feedback causing a metalic sound. I probaly just confused you but good digital delays usually have all the features and will usually do all 4 effects depending on how you set them. If you want delay, set width on 0 and adjust time and feedback. For flanging, adjust width and speed and feedback. Chorusing, adjust time, width, and speed. Reverb, adjust time, set width on 0, and feedback. I see it has a level(mixture, how much effect you hear), and a replay(feedback, how many times you hear it), and a delay knob,(how long the echo will be) The range/mode switch allows for settings of diferent time lengths and INF setting allows for infinite repeat. Hope this helps.
Mar 09, 2013 | Applause MAE148 AcoEle Mandolin Natural...
Cannot format or reload factory presets after it stopped working
The card that you used to transfer the files HAS to be (1) FORMATTED by the ESX-1 unit FIRST, (2) then put the card into your computer's card reader and download the files. (3) Put the card BACK into the ESX-1 and try reloading the factory presets. Good luck!
Jan 11, 2013 | Korg ESX1 Electribe SX production station...
Chorus emits a pulsating noise
Sounds to me like low-end gear. You honestly get what you pay for. If it happens to be high-end then you have either bad cables or just a bad effects processor. If you have on-board effects built into the amp, then get better equipment.
Hope this helps.
Aug 31, 2012 | Ibanez IBZ10A 10 WATT ACOUSTIC AMPLIFIER...
Hi, when I play a chord on my Casio-656 keyboard it sometimes sounds out of tune - if you hit the chord again it plays correctly. Is this a fault or a setting? It seems to be intermittent so that would...
I would check your fingering... You MAY be late in hitting a particular note and the using auto chord... this can cause the problem. Another thing is if notes are hit with different velocity that can affect the sound. Sometimes certain voices have VELOCITY switching which actually changes the voice depending on the velocity you hit a note.
May 19, 2011 | Casio Music
Need assistance in learning how to use thepowered mixer txm20 controlls
Hi there. Just in case you haven;t got it, here's a link to the TXM 20 manual:
http://s3.amazonaws.com/samsontech/related_docs/TXM1620_OM_5L_v3.pdf
If you have this, then let me know what controls your are having porblems with and I will try to help>
All best
N
Apr 22, 2011 | Samson TXM20 20 Channel Powered Mixer,...
MY MXR STEREO CHORUS LED LIGHT START TO FADE AFTER CONNECT WITH DC BRICK! DOES THIS MEAN MY PEDAL WILL HAVING ANY DEFECT?
I don't know what you mean by "DC Brick"...
The MXR Stereo Chorus unit requires a special 18 Volt power adapter. The common 9 volt pedal power adapters will NOT work with this device. If you have batteries in the unit, when you plug in an incorrect adapter, the unit disconnects from the batteries and the caps discharge so the light will fade.
You will need to use: ECB-004 18-volt AC Adapter Best to use the manufacture's exact device for this one.
Jan 12, 2011 | MXR Stereo Chorus Pedal Guitar
Fishman Loudbox Mini Acoustic Amplifier Amp Acoustic Logo
Top Fishman Music Experts
Michial Gueffroy
Don Hart
rhodesworks
Are you a Fishman Music Expert? Answer questions, earn points and help others
