Question about Intel Motherboard
Motherboard Pin Plugin
Hi, my name is Ethan from Malaysia.
I got one motherboard, no manual but i found the manual at internet.
And now the problem is the manual didn't state out which one is PWR/STANBY/RESET/LED.
Here is the manual site
http://www.svbinternational.com/manuals_dir/manualmbd810Etchipsetpdf182kb_Win%2095,98,NT,2k,ME,XP,Netware_979d_manual-810ET%20Main%20board.pdf
And this is the problem, i need Guru to help me.
http://img9.imageshack.us/my.php?image=40243647.png
  • Anonymous Mar 12, 2009
    Thanks for reply.
    Where is your j10b1?
    Thanks you.
    I want need for further assis at Friday, can?
  • 167 Answers
They are not marked with small White letters and lines that visually isolate what ones are what? most boards are marked in this way, you may need a magnifier to see them. i looked over the manual, it is not showing a good picture of it, but i would look on the left side manual view,or the bottom left area, see if you can make it out. the lettering i spoke of. i have had alot of p3 boards in the past, never saw one unmarked. hope this is helpful, if you need further assistance reply. good luck- ok i did some looking do you do you see j10b1? are they marked, other than 1 or 2? this is the one i am looking at now.
Posted on Mar 11, 2009
I also lost my motherboard manual and I need to connect the front panel leds to the right areas so the stinking puter will fire up
google search the numbers on the cmos bios chip to find out what motherboard you have and then google this found number or the name of the motherboard with the words user manual. Hopefully there is a manual on the internet for your motherboard.
Jun 06, 2016 | Computers & Internet
Front header pins for Veriton 3900 STD
I don't think you will be able to find anything this way , I looked and only thing I found was some elite group motherboards..but to be sure ..take a look inside and post the motherboard name ..and after that we can find a motherboard user guide ..cause the diagram you need always is present in the motherboard guide..
So ..either post the name and I will look for it ..or just make a search by the name ..and in the guide look for the front panel..You will have a location of the connector and a tab with order..pay attention on the missing pin for guidance The missing pin is specified so you will now which row will be the impair numbered ..and the wires have numbers and names on it ..specified in the tab ..
I will link one I found and uses the same chip-set ..and if we are lucky is the one you have ..
anyway usually it is the same if it uses same chip-set
here is the user guide
http://eudownload.ecs.com.tw/dlfileecs/manual/mb/eng/p4/G31T-M_V2a.pdf
On page 17 you will find what you look for
Dec 24, 2011 | Acer Computers & Internet
I need to figure out where to plug in the Power LED and the power SW wires to the mother board
Hi
The link for the motherboard manual can be found here, on which there will be a pinout diagram of the Fpanel pin headers
http://www.abit.com.tw/page/en/download/download_manual_detail.php?pFILE_TYPE=Manual&fSEARCHTEXT=kt7a
USUALLY the wires are marked as:
Power switch: PW
Power led = Pled
On the motherboard you will see (bottom right corner I think), a group of about 8 pins in a block, this is the Fpanel pinset. on the motherboard next to each pin SHOULD show the wire connections as described above, but consult the manual to be sure.. this is a VERY old mobo
Dec 28, 2010 | Abit KT7A Motherboard
Hi! Help me, please, I dont know how to connect front panel with connector on motheboard Chaintech 9BID1. I can't found motherboard User Manual... Thanks!
The pins should have markings on the MB saying which connector goes to what pin.
If not here's a diagram
Hope this helps
Dec 17, 2010 | Chaintech (9BID1) Motherboard
I have an Asus P4P800MX/S motherboard I got on Ebay. It came with no manual. The front panel connector is a 10 pin connection on the motherboard but the manuals I got from Asus state they are all a 20 pin...
https://www.manualslib.com/manual/444313/Asus-P4p800-Mx.html?page=38#manual
Page 38 is the front panel 20 pin connectors; if you have a 10 pin, you don't have that model. I would search the manual I linked to for the motherboard picture so you can determine what the 10 pin really is.
Dec 27, 2017 | ASUS P4P800-MX Motherboard
Chaintech snf4-2 motherboard
Are you sure that its name is SNF4-2? Isn't VNF4-2?
Dec 22, 2007 | Chaintech SNF4-2 Motherboard
Memory
Unplug both ram dim. Plugin one single ram dim and check. Remove first and plugin second dim then check is detected ? If both are detected one by one then check clock speed of both rams , it should match, otherwise only one will be detected. Also check motherboard manual for supported ram eg. ddr1, ddr2 , cloack speed etc.
Thanks,
Vksr
Oct 13, 2007 | Asrock 775Dual-880 Pro Motherboard
Intel Motherboard Logo
98 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
