Question about Andis Outliner II Hair Trimmer
My Andis Masters
1)are not cutting properly. I have replaced the blades and they basically pinch and pull. 2)The clippers slide out of adjustment settings.3)The clippers also get hot in a short amount of time.
Please advise.
  • 61 Answers
Tention is probably to tight, or blade needs to be realigned
Posted on Apr 01, 2009
Blade not staying on tight
If you can pull the blade away from the clipper without pressing the blade release button then either the hook on the Latch is broken (which will mean all blades have the same problem) or the blade socket on the blade may need adjustment or replacement. Please view the part in question Latch
Mar 12, 2014 | Andis Agc Super 2-speed Clipper...
They are not cutting properly just the fluffy outer coat
If the blades are new or have been sharpened they may have become misaligned. the upper blade should be no more than 1/16" from the front base plate blade. Another reason could be the tension on the blade. If the screws come loose or if the spring steel weakens or breaks hair will just slide between the blades. With the blades ff the clippers slide the upper blade to one side or the other. It should take around 3 pounds of pressure to push the blade back to center. If it is less or more both can cause the problem.
May 12, 2011 | Andis 22340 Agc 2 speed Professional...
My andis t-outliner keeps pulling hair when cutting and it barley cuts the hair. Do the blades need adjusting?
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Jun 08, 2010 | Andis 01690 Hair Trimmer
Misses hair when cutting
You probably need a new blade drive, which is easily replaced yourself, if you are so inclined.
Apr 20, 2009 | Andis 01690 Hair Trimmer
My GTO model Andis clippers blade is not properly aligning..how do I adjust it?
The problem with Andis clippers is that you are not told how to get the most effective job out of you're clippers,i can attest to that because i've repaired and adjusted hundreds of them,every user wants a crisp cut,nothing less, you want find the answer to that in the instructions,so you're encouraged to send the clipper back to Andis company,i did that once just to see if they really understand their own tool,the clipper cut no better upon it's return,it was then that i discoverer the ultimate solution,blades has to be precise,only then will you get a crisp cut,for any type of hair ,so before you get rid of blades,remember 85% of the time the problem is with the adjustment of the blade.
Dec 17, 2008 | Andis 01690 Hair Trimmer
Shaver no longer cutting well
Have you been keeping the blades cleaned and oiled well? How long have you had the clipper it may be that you need a new blade? This trimmer is not truly intended to do a complete clip on a poodle it is for trimming. Please call Andis customer service at 1-800-558-9441 for further instruction.
Dec 14, 2008 | Andis 18050 Hair Trimmer
My andis clippers are experiencing blade not moving. it is not cutting.
Push top blade to right side right with finger,then turn clipper on and dip  into 3 in one oil,blades only,let clipper run for one minute,clean excess oil off blades,if clipper still want vibrate,take blades off the clipper and clean them,then place back on clipper, I've had this problem many times,i also repair clippers,adjust blades,etc...
Oct 09, 2008 | Andis 01690 Hair Trimmer
Putting blade back on my Andis dog clipper
It sounds like you may have a bent hinge which is what the blade slides onto. Please call Andis customer service at 1-800-558-9441 to speak with a customer service rep. They can give you instructions on where to purchase a new hinge or send or clippers in for repair.
Thank you,
Jun 17, 2008 | Andis 29745 Clipper Headliner Hair Trimmer
Andis Outiliner II Trimmers
Please return your unit to the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177 for repairs. If the unit is less than one year old please also return a copy of your receipt with the unit and all repairs will be done at no charge. If the unit is older than one year there is a $6.50 service fee and $5.00 shipping. There may be additional charges for parts depending on what needs to be done. If you would like to speak to an Andis customer service rep please call 1-800-558-9441.
Thank you for purchasing Andis.
Dec 21, 2007 | Andis Outliner II Hair Trimmer
Andis Outliner II Hair Trimmer Logo
594 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Kolbrun...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
