Question about Olevia LT32HVM 32 in. LCD Television
How to fix the invalid format for my ps3 or xbox
My online pass says its invalid
The code may have been used before or maybe you need to install recent updates
Nov 02, 2012 | Electronic Arts FIFA 13 [PS3] Xbox 360...
My tv says invalid format when i connect my ps3 using an hdmi cable
Your PS3 is sending a 1080P signal to a TV that can only handle 720P or 1080i. Connect the PS3 using the A/V cables, fix the resolution and then go back to HDMI.
May 02, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
What to do when the ps3 shows "invalid format"?
For games, it means you inserted a unsupported disc. This is usually the case when say, inserting a xbox game into the PS3, or when trying to play a copied game.
For videos or music files, the format is not readable by the PS3. In this case, you should convert to something that is supported.
Jul 14, 2009 | Sony Playstation 3 (PS3) Console
"Invalid format" PS3 / LG
Try holding down the on/off button until it beeps once. this should reset the display to the original setting.
Hope this Helps
-Cody
Jul 06, 2009 | Sony Playstation 3 (PS3) Console
"Invalid format" how do I change from 1080p to 1080i or 720i?
I had a second playstation hooked to another tv in my home and took a controller from the non-LG-TV-displaying ps3 and one from a working ps3 on a seperate TV. And used the working ps3 to guide me to the settings menu on the ps3 that was not displaying video. Anyways, if you cannot see the tv screen because it is set on 1080p and your LG will not display it (Only displays up to 1080i). Start The PS3 and press the D-pad buttons in this order.
Left 10+ times. (This Takes you to the far left icon in the XMB)
Right Once. (This is the settings icon)
Down 20+ times. (To reach the bottom of the settings)
Then Up 4 times (This is Display Settings)
Press "X" Once. (This enters Display Settings)
Press Up 5 times (This Makes Sure you are at the top of the sub-menu at Video Output Settings)
Press "X" Once (This Enters Video Output Settings)
Before pressing any more buttons, Know what cables you have pluged into your TV.
For HDMI Just Press "X" and it will auto adjust to for the new TV.
For Component / D-Terminal Output Press Down Once Then "X", and X Again (This changed my ps3 from the 1080p-Invalid Format back to 1080i and fixed my problem.
For Composite Video Output Press Down Twice, Then "X" and X again.
For AV MULTI / SCART Output Press Down Three Times, Then "X"and X again.
Apr 26, 2009 | Televison & Video
Invalid format??
change the display settings to 1080i or 720p- his tv likely does not support 1080p.
Mar 30, 2009 | Sony Playstation 3 (PS3) Console
Invalid format
my xbox 360 when hooked up to my 42inch Lc7d get sound but displays invalid format error,  how can this be fixed?
Jul 07, 2008 | LG 42LC2D 42 in. LCD HDTV
Olevia LT32HVM 32 in. LCD Television Logo
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
