Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
My kud101flss2 will not start
Good morning, today i wanted to run my dishwasher it is a kitchenaid KUD101FLSS2 built in and it had a small amount of water that did not drain from the previous wash and none of the button lights will go on, i thought it might be locked but its not. Three nights ago no water would spray so I read in this website that I should try moving the part that looks like a mushroom up and down and It worked it ran perfectly, but now this.
  • Anonymous May 06, 2009
    I'm having a similar problem with my KitchenAid KUDR01TJBT0. I do not know if it said clean or not when my daughter last emptied it but now the panel will not function and there is water in the bottom. I seem to have had this problem before and think they replaced the motor, but my wife was at home not me so I don't know for sure.
  • 37 Answers
First be careful about electrocution-did one of the wires come loose underneath-but don't touch anything. Check to see that it is plugged in and also that the fuse is not blown or breaker tripped. If this does not resolve the issue, if not hardwired, check for a tripped outlet and try another electrical item in the outlet to be sure that power is going to the outlet. Another posibility is that for some reason the door is not locking and allowing the knob/dial to engage. Open your dishwasher and look at the top of the door-does the bar come across when you lock it? Keep it open and turn the knob all the way around to the end of cycle position. Close and lock the door and try again.
Posted on Mar 16, 2009
Frigidare fdb1500lfco
Good Morning Kristen - You may try to reset the dishwasher by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the dishwasher back on. If this proves to be ineffective, then the unit may possibly being experiencing a communication issue with the control panel, wiring failure, drain motor/pump or water valve. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
May 28, 2013 | Frigidaire 24 in. FDBB840DC Stainless...
Is there a drain or screen to remove and clean, have small amount of water in botton of dishwasher, always there
A small amount of water is normal and is needed to keep the rubber gaskets from drying and leaking. If it still cleans good don't worry about it.
Dec 28, 2010 | Kenmore 24 in. 16039 Built-in Dishwasher
Small amount of water leak during run cycle
Here is a tip that I wrote about leaking dishwashers...
There also is a link in there to another tip on how to buy parts online for your dishwasher...
Leaking Dishwasher
Jun 05, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
Small amount of water covering bottom dishwasher-won't drain
Mar 10, 2010 | Maytag 24 in. MDB3700 Built-in Dishwasher
Water doesn't drain. none of the buttons work, now.
hello sir
please check whether the power supply is reaching the machine or not.
Jul 06, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Water will not drain from Kitchen Aid Dishwasher
my dishwasher did this for awhile. i found a small object lodged in the drain under the moving sprayer. i put a small amount of powdered clorox2 and ran a cycle. afterwards i ran a jetdry cycle. i havent had a problem since.
Apr 23, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Soap stays on dishes, pump a little noisy Dishwasher is 5 years old
first thing to check for is your fine srtrainer remove it clean it verry well because lint stick inside the edge of the filter causing blockage of amount of water to be pumped out neck thing to check for is the amount of water that comes in to the machine start the machine listen for the first fill to complete open the door there shoud be aprox 1inc of water in the macine if not its possible that the drain valve have something stuck inside causin to loose water to see if its your drain vale when you have check the amount of wate reclose the door let the pump run for a min then reopen the door if you have less water check your drain valve or your check valve normally blue or white aprox 3"long inbetween two hoses thanks from gilles
Mar 15, 2009 | KitchenAid 24 in. KUDS01ILWH Built-in...
Check whether the drain line was assembled exactly as per Kenmore's instructions. Good luck!
Sep 10, 2007 | Kenmore 24 in. 16032 Built-in Dishwasher
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
421 people viewed this question
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
