Question about Garden
How do you replace the bearings on a z520a john deere mower
I cant get the top nut to come loose on the deck to get to the bearings, any suggestions?
SOURCE: replace blades on a john deere L120 mower deck
First make sure you have the tools, metric that is. The deck must be removed and turned over. To do this you must put the deck in the lowest position. Using a 15mm socket pull the belt tension spring pulley forward to detach from clutch. Next remove retaining pins located at the five deck brackets. This will allow the arms to slide off and the deck can be dragged out from under the mower. Turn deck over. Use a 18 inch 2x4 to block blades while removing the two 15mm bolts. The bolt heads will need to be cleaned so the socket can seat on bolt head. I use my torque wrench to get more leverage and i can use it to reset blade bolts to 64 ft lbs. While blades are of it is a god time to thoroughly clean underside of deck.
Posted on May 25, 2009
SOURCE: john deere 111 mower deck. Lift is in stuck in highest position
Looked up detailed isometric diagram w/ parts denoted on John Deere website. FixYa website was a litele misleading. I did not realize that accessing a question posted "for free" would cost me something to get the answer. It's kind of like askin a neighbor as a neighbor to give you a hand and then he sends a bill.
Thanks but no thanks
Posted on Jun 26, 2009
  • 218 Answers
SOURCE: I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN
Hi..my name is Keith..and you can go to an online lawn mower parts site and put in your model of lawn mower and search for the mowing deck..and they will have a diagram of the mowing deck with the belt on it..and there are several sites online but i'll give you the one i use www.outdoordistributers.com ...i hope this has helped
Posted on Jul 12, 2009
SOURCE: need to replace belt on deck of john deere riding mower
does the belt on a 42" scotts lawnmower go behind the tenisoner or in front of it?
Posted on Jul 25, 2009
  • 5 Answers
SOURCE: need john deere stx38 mower deck belt diagram
Go to http://outdoorpowerinfo.com/repairs/deere_stx38_gear_drive_belt.asp
for pictures and descriptions of drive belt and deck belt on John Deere STX38 and STX46 tractor with black deck
Posted on Oct 22, 2009
I replaced a bearing and seals in my john deere 185 hydro and put new belt on. Now when I put it in foward it goes in reverse and reverse when it will go forward. What did I do wrong.
Sounds like the lever on top of the transaxle where the rod hooks into was put back on wrong. Take the rod loose, take the nut off , lift the control lever up and rotate it half a turn and put it back down, replace nut and rod and try it.This would reverse the action of the push and pull of the rod.
May 10, 2016 | John Deere Garden
I need a diagram showing how to route a mower deck belt on a John Deere model 240 mower deck. My spring has fallen off and I need to know where it goes to put the tension on the belt.
Here's a link to an online John Deere parts store. When you land on the page, look at the top sub categories for the size of deck your mower has. You should be able to access a parts diagram with pictures of your belt's proper placement.
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Mar 07, 2016 | John Deere Garden
Keep burning up deck belts on 20yr old John Deere rider rx75. What size belt should I be using
1/2 x 60
Check all deck idler pulleys and make sure no bad bearings or flat spots
Apr 24, 2015 | John Deere Garden
How to replace transmission belt on x324 john deere lawn tractor
Remove 3 bolts and guard-A
Loose hardware-B-C
Remove nut-D
May 01, 2014 | John Deere Garden
John Deer 100 series Having problems with the mower deck. Started hearing a ticking sound while mowing. stopped to clear a possible obstruction. pulled PTO knob and it is down right jammed up! wants to...
Check that the blades spin freely by hand. That may be in contact with the deck somewhere or one of the deck bearings may be seized. Regards Phil.
Apr 12, 2011 | John Deere Garden
I HAVE A JOHN DEERE RIDING MOWER AND I AM TRYING TO CHANGE THE MOWER BLADES, THE BLADES WILL NOT LOCK SO I CAN TURN THE NUT THAT IS HOLDING THEM ON. SO HOW DO I LOCK THE BLADES SO THEY WILL NOT TURN?
you need to remove mower deck....and with correct size wrench hit it wrench with copper hammer to shock it loose....then do the same when tightning them up
Aug 11, 2010 | John Deere Garden
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
