Question about Generac Guardian Electrical Supplies
Guardian rv generator starts popping when turning on hair dryer. Why does this happen?
I am a mobile dog groomer and my system runs by a 6500 watts Generac Guardian. Every time we turn on our largest hair dryer it starts to pop and we have to go the the breaker and shut off the power and turn it back on to start. Sometimes we have to do it several times for it to quit. It only does it with the largest dryer. When turning on the smaller dryer we have no issues. What could be causing this problem and how can we fix it please. Thanks, Maureen
    New Friend:
  • 5 Answers
What is the wattage of the hair dryer?. It sounds to that your hair dryer is drawing to much power for the generator.
Posted on Apr 20, 2013
  • Maureen Kirksey Apr 20, 2013
    It just started to do this. It use to work fine. What would have changed? And it does not do it every time I use that dryer.
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    I have a Guardian RV 3600 watt generator than wont run more than a few seconds. I have to hold my hand over the breather to get it to fire then as soon as it revs up it shuts off.
    carburetor restricted due to long time storage drop carb fuel bowl unscrew the jet and pull down the fuel tube clean them and your generator should run much much better
    Aug 16, 2013 | Guardian Rv Generator 4800 Watt, Gasoline,...
    My generac 40g rv generator will start fine but no power. I noticed that when it starts the microwave will power up for just a second. I can turn the generator off and on a couple of times and then it will...
    It may be demagnetised. If you turn off the generator before unplugging the load this may happened. Try to put a strong magnet (like those from loudspeakers) in contact with the body of alternator. I do this in the past and it work.If you do not know how to do this ask an electrician, he can help you .
    Sep 30, 2010 | Guardian Rv Generator 4800 Watt, Gasoline,...
    Onan Portable Generator - 5000 , Model# 6500: I have china generator capacity is 2700 watts but ...
    Alternately,
    • Turn-off all lights first.
    Run your pump or water start motor.
    • When the motor is running,
    Turn on the lights , one at a time.
    May 18, 2010 | Watts Onan Portable Generator - 5000 ,...
    Your control board is faulty. Try to power up the ingnition coil as well as your fuel pump. If this does not get the engine running then you have major engine problems.
    May 18, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
    I have a 7500 watt guardian rv generator and it is difficult to start if not used on very regular basis. It cranks but will not fire. If I go out and manually fool with the choke it starts. Obviously it is...
    Before starting the genset remove the air filter and check the throttle plate on the carberator, it should be closed. If it is opened, then you choke coil is worn out and needs to be replaced.
    Apr 19, 2009 | Guardian Rv Generator 4800 Watt, Gasoline,...
    Have a 16k propane guardian generator have to manually start and
    Is this an RV generator?
    If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
    Rate me,
    Carl
    Nov 19, 2008 | Guardian Rv Generator 4800 Watt, Gasoline,...
    Electrical Supplies Logo
    177 people viewed this question
    Top Generac Guardian Electrical Supplies Experts
    Craig Butler
    Craig Butler
    jdthefixer
    epangan29
    Are you a Generac Guardian Electrical Supply Expert? Answer questions, earn points and help others
