Takeuchi TB.030 turntable bearing - Audio Players & Recorders
Which rod bearings???????
what you are seeing are under sizes for bearings available for when the crankshaft is ground
you have to measure the journals with a micrometer to see it it is standard size or has been ground
or if you are just putting new bearings in during a quick engine rebuild then the bearing size will be stamped on the back of the shell
it will be either std or the .010" etc and you need the bearings with that size on them
anything else but std on a std crank journal will jam the shaft up--or .010" means that the crank has been ground .010" and needs bearings of that size
conversely if you put std shells on a .030" ground shaft , the bearings will flog out and oil pressure will be low to non existant
Mar 15, 2016 | Cars & Trucks
Why wont my takeuchi backhoe not start when it is hot?
Jims excavator #30 Part two of my starter installation on my ...
? 13:50
www.youtube.com/watch?v=EoEMoBb1bPU
Jan 12, 2012 - Uploaded by JimsEquipmentShed
This is the second time I've put this starter in, so this time around, instead of removing the rops and ... Thanks! i have a problemwith the heating in de cab. ... B-) The Takeuchi is a great machine though, I'd buy another one.
Aug 05, 2015 | Cars & Trucks
Califone 1420 k speed fluctuation
Take the turntable off by removing the "E" clip on the top center of the turntable. You can then oil the motor, lube and check the main turntable bearing and most important, clean, lube and adjust the idler wheel. The rubber tire on the wheel can be cleaned with alcohol or rubber cleaner and this will fix most speed problems. The height of the wheel can be adjusted by changing the fiber washers and of course the wheel bearing should be greased.
Aug 09, 2013 | Califone International 1030AV Turntable
Thread size of takeuchi tb016 grease nipples
broke a greese nipple on my takeuchi tbo16 can you tell me the size
Mar 13, 2012 | Cars & Trucks
Our Spacemaster Microwave can make occasional loud grinding or vibratory noises--deep and low sounds. Solution?
If it has a turntable, the wheels are worn or dirty and are chattering. When I have this problem, I take out the turntable, clean up the floor of the oven, the bottom of the plate, and the wheels on the turntable ring. Then I push a small amount of paste wax (made by S. C. Johnson) onto the axles inside the wheels to lubricate them. (I've kept my worn-out turntable ring going for over 10 years by doing this.) If the turntable has a central post through the floor of the oven, the bearing may need cleaning and lubrication.
Other possible causes would be the bearings in the magnetron cooling fan or the microwave stirring fan in non-turntable models. Excessive dirt on fan blades can cause imbalanced running, which will also generate vibrations.
Dec 30, 2010 | Microwave Ovens
The turntable is like stuck or something. It was spinning fine and now it doesn't spin freely. Whats the problem?
If the motor is working you need to remove the plater and check the center bearing it might sunk or got stuck for some reason. The lube might dried out, and the hard ball bearing had worn into the soft brass that the tube was made from. Relubing, and replacing the ball bearing with one of a larger diameter, can cure the problem.
Nov 30, 2010 | Stanton STR8-60 Turntable
Need schematic for current limiter connection on Takeuchi Excavat
I emailed Takeuchi with a request for the schematic page. Takeuchi emailed me the page.
Sep 02, 2009 | Garden
Need to get code for 3-1 remote # 1519001
TV Brand 3-in-1 Code Radio Shack Cat. No.
Akai 098
Anam 068, 180
Anam National 055, 161
AOC 019, 030, 052, 137
Candle 030, 046, 056, 186
Capehart 052
Citizen 030, 039, 046, 056, 060, 092,
186
Concerto 056
Contec 158, 180, 185
Craig 161, 180
Crown 039
Curtis Mathes 030, 039, 060
CXC 180
Daewoo 019, 039, 091, 092
Daytron 039
Electrohome 039
Emerson 039, 158, 177, 178, 179, 180,
181, 182, 183, 185, 236, 270,
280, 282
Envision 030
Fisher 154, 159
Fortress 093
Fujitsu 179
Funai 179, 180
Futuretech 180
GE 021, 027, 029, 047, 051, 055,
174, 178, 282
Goldstar 001,019, 039,056, 106, 178
Hallmark 178
Hitachi 038, 039, 056, 095, 097, 145,
151, 173, 227
Infinity 054
JBL 054
JVC 053, 169
Kenwood 030
Kloss 046
Kloss Novabeam 024
KMC 106
KTV 039, 180, 280
Logik 016
Luxman 056
LXI 047, 054, 148,154, 156
Magnavox 020, 024, 028, 030, 054,
096, 186, 187
Marantz 030, 054
Memorex 016
154 16-229
178 16-254
16-263
16-280
MGA 019, 030, 150, 155, 178
Mitsubishi 019, 098, 155, 178
Mitsubishi Unified 150
MTC 019, 030, 056, 060, 091
Multitech 217
NAD 156, 166
NEC 019, 056, 170
NEC Unified 030
Onwa 180
Optonica 093, 165
Panasonic 051, 054, 055, 162
Penney 018, 019, 021, 030, 039, 047,
060, 135, 149, 019, 020, 024,
028, 030, 054, 186, 187
Phillips 000, 054
Pioneer 038, 166
i think this will help you a lot.
Aug 03, 2009 | Televison & Video
Record player does not move
more info needed - could be that the 'belt' driving the turntable has slipped or broke - what type of player is this?
Jul 18, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
How to remove platter from AKAI AP-B110 turntable
On my Akai turntable, I have to remove the fiberboard bottom cover (nine screws, nothing tricky) then there's a central brass air bearing with a small set-screw in the side. Loosen the screw, and the central turntable axle lifts right out of the bearing.
This is a belt-drive Akai - your mileage may vary.
Mar 24, 2009 | Audio Players & Recorders
 Grubhead
Grubhead
