Question about KitchenAid KEYS850LQ Electric Dryer
Kitchen aid electric dryer won't start. The door is securely closed and the light switch turns the light off and on. When you cycle the timer all the way around, the start switch clicks when depressed, nothing happens and repeated pressing of the start button does not click until you cycle the timer all the way around again.
  • Tommy99 Apr 25, 2009
    I checked the thermal fuse, it's good.
  • Anonymous Apr 27, 2009
    Exact same problem
  • 686 Answers
Change your thermal fuse
Posted on Mar 12, 2009
Won't start
Is door securely shut? Safety switch could be preventing start. Might try unplugging for about 1 min, then plug back in and try. On some models, this will allow circuit to reset. Good luck!
Apr 08, 2014 | GE GFDR485EFMC GFDR485EFMC 8.3 Cu. Ft....
Buzzing noise from my dyer
You may be experiencing some feedback through a buzzer from the timer. Below is a link that may be of some help.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Oct 23, 2017 | KitchenAid KEHS01P Electric Dryer
Lights come on, press start and nothing ..
Start Switch is bad, When they go out it leave's a open circuit and all light will come on but no action.
After the circuit is closed then it tells the dryer to start cause the circuit activates both the timer and the motor.
Good Luck
Mike Z
Dec 01, 2013 | Whirlpool Cabrio WED5500X 27" Front-Load...
Kitchen aid gas dryer lights up but won't start
What is the model number? Look inside the door jamb.
Oct 19, 2012 | Whirlpool GEX9868J Electric Dryer
Kitchen aid dw won't start,, the lights come on it beeps at me but won't start the cycle... also, during a cycle i can open the door and it doesnt halt the cycle, it just keeps on going
see this causes:
Power from the house
reset the c.breaker from your hose or replace blown fuse inside the machine.
Door switch
test the door switch for open or defective this will NOT permit to close the relais for start the motor
Wiring
loose wiring, break or burn repair
Timer or selector switch
selector switch, open or defective, timer defective, however clean contacts diryt or oxide, loose wires, break or burn. GOD BLESS YOU.
Jun 21, 2012 | KitchenAid Dishwashers
Whirpool Fronload Dryer has power, timer cycles through, but it is not running. The dryer worked two days ago when I ran a load. I went to dry a load this morning and it turns on, everything lights up...
The reasons can be a fault on the program controller unit but as the door does not close the program also will not move further. This must be the clue to the fault. Remove and check the lock and the settings. manually close the door with force and see if the program cycle starts, if not check the door switch and the control panel. Also check for output when the timer counts down. If not the controller unit must be checked for possible problems.
Nov 14, 2011 | Whirlpool GEW9250 Electric Dryer
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
I have a kitchen aid electric dryer Model KEYE660WWHO, serial #1422813. My dryer won't start. The fuses have been checked and are fine. When you select the drying time, you can hear it ticking, but when...
ma be the door switch push on the door switch with a screw driver to see if it comes on if it does you have found the problem. If that does not work let me know and I will help you solve the problem.
Nov 28, 2009 | Office Equipment & Supplies
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
KitchenAid KEYS850LQ  Electric Dryer Logo
1,445 people viewed this question
Top KitchenAid Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Oloyede Monsuru
Are you a KitchenAid Dryer Expert? Answer questions, earn points and help others
