Question about Rv Motorhome Dual Co & Lp Gas Alarm Detector
1989 palomino txl pop up cable diagram
The cable has broke in several places and has been sliced together. I am not sure if even the cable is going in the right direction. even tho the camper will raise it is most definetely in a bind!
2 Suggested Answers
SOURCE: MANUAL--Used Palomino TXL Hard sided popcamper-- MANUAL
I have a manual for a 1998 TXL. I can make you a copy for a small fee
Posted on Aug 03, 2010
I have power to palomino ss550 pop up it wont raise
check all safety switches,look at diagram in repair manual,down load manual off internet
Nov 21, 2016 | RVs
My Kitchenaid toaster lever plastic knob broke off. I epoxied it and it worked for a while, but then broke again. I found a replacement part somewhere online but now can't find the site again. Do you...
Should not be a problem.
Most toaster knobs just push on.
Some are held in place by a metal clip that increases the friction. Some are held in place by a tiny set screw on the bottom of the knob.
You'll figure it out.
Feb 16, 2014 | KitchenAid KMT4115CU Contour Silver Four...
Emergency brake cable broke
Usually you have a long cable from one wheel to the other with a connector in the middle for the front cable to attach to it...
Aug 26, 2009 | 1989 Chevrolet Cavalier
Cable input jack bronken off
Actually I just repaired one of these "similar" units. If you remove the backing of the tv, unpluged of course, Theres a panel facing you if you are looking at the right side of the TV. This panel pops off easily with a light prying motion all around. You'll see where the connector broke off and can solder it back together with a small pin type tip. Solder the center pin to the center probe first,hold in place with needle nose pliers. 2 people are better than one at this. Then lay down agood bead of solder around the perimeter of the connector. Clean up any solder that may have dropped and put it back together, you'll be ready to go in about one hours time. Let me know how it goes!!!
Jul 25, 2009 | Orion STV2763 27" TV
Jun 07, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Repairing rear suspension on 1989 RS Camaro now
try Schram auto and truck parts they sell only GM parts 1-800-292-1032 and you can also try autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
Mar 12, 2009 | 1989 Chevrolet Camaro
Lever broke
The plastic used is a thermoset, so should not want to melt in order to join together again by that method.
I would recommend using a clear 2 part epoxy resin. Make sure all parts are clean using a degreaser - cleaner, and dry thoroughly for several hours before repair. Use elastic bands or tape to hold items in place while the adhesive sets - about 24 hours for full cure.
If there is still a problem after this, please contact again, or rate so that other may follow the advice given. Thank you.
Jun 08, 2008 | KitchenAid KTT570 4-Slice Toaster
Sliced control cord
Obviuosly,the tiny wires inside the insulations have more often than not,red and or white colors and you might have erroneously reconnected them through soldering.Yet,you didnt get the desired result.Visit an electronics spareparts store nearest you but make sure you bring the damaged cord with you,Inquire from them for a compatible cord which you can use as a replacement because if you continue using tis damaged cord might severely affect the entire system.Thanks.
Sep 26, 2007 | Altec Lansing ATP 3W Computer Speakers
Rv Motorhome  Dual Co & Lp Gas Alarm Detector Logo
76 people viewed this question
Top Camper Vehicle Parts & Accessories Experts
Mike
Ken Strite
Ken Strite
Are you a Camper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
