Question about Philips SA6025 Digital Media Player
When i turn on my player message comes "wait for USB connection". How should i fix it?
  • 8,596 Answers
It could be a hardware issue requiring replacement, but here are the things you can try to narrow it down:
1. Make sure the hold/lock is not engaged
2. Reset the player
3. Run an Updated using the latest version of the Philips Device Manager from Philips website
4. Run a Repair in Philips Device Manager
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 18, 2009
I erased all the songs from this mp3 play to put new ones on after erasing the songs the play won't be picked up by pc and am unable to put new songs onto mp3 plaey the players just displays please wait...
yes...unplug from pc shut mp3 off for a minute...plug it to pc (did it come on turn it on)...please get into the habit of disconnecting any usb connection with the safety disconnect...(green icon in task bar when usb is connected)...since you already deleted all files (format it now) start fresh...now you are able to put your songs on it...but to disconnect do not....do not just unplug the usb
Jun 20, 2010 | RCA M2000 MP3 Player
When I try to sync my itouch I get an error
Try restoring it...here's how...
  1. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  2. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  3. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" , let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.
  4. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  5. When you see "Connect to iTunes" on the screen, you can release the Home button andiTuneswill display the recovery mode message:
    If you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Sep 08, 2009 | Apple iPod touch
My Ipod touch won't turn on
Sep 07, 2009 | Apple iPod MP3 Player
My ipod is disabled and my computer wont let me fix it
you can reset its password....but you'll lose all your data. Here's how...
Sep 05, 2009 | Apple iPod touch
How can i fix and ipod touch that says ipod is
You'll hv to restore the ipod..here's how...
  1. Verify you have iTunes 7.5 or later. Apple recommends using the latest version of iTunes.
  2. Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
  3. Power off the device (Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
  4. Press and hold the Home button while reconnecting the USB cable to iPhone. When you reconnect the USB to iPhone, the device should then power on.
    Note: If you see the message "Charging... Please Wait" or you see the screen pictured below, let the device charge for at least 10 minutes to ensure the battery has some charge and then start with step 2 again.ht1808_01.jpg
  5. Continue holding the Home button while iPhone starts up. While starting up, you will see the Apple logo.
  6. When you see "Connect to iTunes" on the screen, you can release the Home button and iTunes will display the recovery mode message:
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6
Aug 26, 2009 | Apple iPod touch
Itouch is diabled someone put a password on it and all that comes up is the number pad for the password. will not connect to itunes either
    ht1808_02.jpgIf you don't see the "Connect to iTunes" screen, then disconnect the USB cable from iPhone and repeat steps 3-6.
Aug 13, 2009 | Apple iPod touch
Passcode do not come on it says connect to itunes but i cant because i have a code on my ipod
If its not an ipod touch,connect it to system and when it gets detected as a removable disk,goto ipod_control>device filder and rename to _locked to _unlocked.. If its an ipod touch Force it into recovery mode...here's how
Aug 10, 2009 | Apple iPod touch Second Gen (8 GB,...
Screen
my screen says the same thing i turn it on an everything starts off fine then after the go gear logo it says(wait for usb connection) i would realy like to fix this problem only had it a few days an got it as a gift
Aug 11, 2008 | Philips GoGear Flash MP3 Player
Continous refresh database
I've got the same problem too. I read this on another website: 'well firstly drain the battery and then connect it to charge it up a bit. once it has been there for 5min or so take it off and then turn it on>settings>USB Mode>MSC once you have done that connect it up and it should work/recognise the player. i don''t know how this thingy happens but this is just how i fixed mine!' I'm gonna try it now on mine, and see if it works. I've just got to wait now... Good luck with yours.
Apr 10, 2007 | SanDisk Sansa e250 MP3 Player
Battery Problem???
Ok it takes a while but heres the solution. Slide the hold button to ON and hold down the REC button.While still holding the REC button,connect the USB port and wait for your PC to find it. Once it has found it type this link in to download Firm Ware. It may take a while but it is worth the wait.Once it is downloaded to your player EJECT!!! the player before disconnecting the USB port.Now just wait for it to format yor player and it should be working good as new again. =)
Mar 06, 2007 | SanDisk Sansa e260 MP3 Player
Philips SA6025 Digital Media Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
