Question about Treadmill Doctor Proform 325 Treadmill Walking Deck
How do I recalibrate my proform 3251 pulse monitor treadmill
Proform 1450 treadmill incline problems
try to calibrate incline. For that check the video
https://www.youtube.com/watch?v=uz1cMWei7AQ
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Mar 12, 2016 | Proform Pro-Form Performance 1450
The incline is stuck in the highest position
Try recalibrate. If that dont work, replace the incline motor.
  1. Press speed^ and stop simultaneously
  2. Insert key
  3. Press stop once
  4. Press Incline up
  5. (This should recalibrate incline). If this fails, replace the incline motor.
Dec 31, 2013 | Proform Perspective Es Treadmill PFTL99806
Incline trouble.
You most likely have a wiring harness problem. Get parts at usedtreadmillrepairparts.com
Dec 25, 2013 | Proform 7.0 Crosstrainer Treadmill
My Proform 730 worked great last spring when it was put away for the summer but now the belt pulses repeatedly for about 1 second on and then off. Any thoughts?
hi, do you have the instruction booklet if so check if your treadmill uses oil. alot of treadmills use oil just like a car. and if it dosent get some wd40 spray and with the power off give the motor a spray and the rollers. the same thing happened to me and i sprayed the motor every moving part i could see. then i left the treadmill on without standing on it for half an hour and its been working better than before. please note wd40 spray can smell abit so open the windows. hope i have helped!
Nov 11, 2010 | Proform Exercise & Fitness
Every time I put the key in my Proform 590T, the incline rises for a second, and lowers for a second while displaying 2 hash marks. Then, the home screen comes. All speeds work fine for walking/running,...
how long have you had this treadmill? usually when the hash marks appear it means that the console control board is not recognizing the incline motor. even though it does run a little bit that is just the basic test that the treadmill starts but resets after it does not sense the incline motor. These motors rarely go bad so it is more than likely your motor controller that is causing the issue. I have seen this case many times as i am a fitness repair technician. The motor controller fixes the issue 9 times out of 10
Aug 05, 2010 | Proform 590T Treadmill
Proform treadmill doesnt work
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
May 26, 2010 | Proform Perspective Es Treadmill PFTL99806
Proform model 480E incline function not working
I have a proform 740CS that needed to be recalibrated.
There is a sequence of steps that I posted that "may" help you
Feb 27, 2010 | Proform Exercise & Fitness
Incline not working,but lever works
Try recalibrating. There is a trouble shooting guide under the hood (motor cover) of the treadmill. It will have the calibrating proceedues there.
Nov 15, 2009 | Proform Crosswalk 500 Treadmill
My Proform treadmill will not incline. It is stuck at about mid incline. When I turn on the treadmill, it raises and lowers back to mid incline right away. Despite pressing incline buttons, there is no...
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Jun 17, 2009 | Proform Sport 1000 Folding Treadmill...
Treadmill Doctor Proform 325 Treadmill Walking Deck Logo
19 people viewed this question
Top Treadmill Doctor Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Matt Olenzek
Matt Olenzek
Are you a Treadmill Doctor Exercise and Fitnes Expert? Answer questions, earn points and help others
