Question about Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350
How to get cleaning solution to mix with water hose?
Noise in the water heater valve. How do I fix it?
Valve is not identified.
Cold water shut-off valve, TP valve, check valve, mixing valve, drain valve are the usual suspects associated with electric water heater.
Gas water heater has additional valves: gas shut off valve and gas control valve thermostat.
Check valve, TP valve and mixing valve probably need replacement.
If drain valve is leaking, put garden hose cap over end.
Shut off valve probably has a bit of blockage, or is not completely open. Try closing and then opening shut-off valve all the way, and if problem persists, replace or clean out valve.
What kind of noise? Are you sure the noise is from a valve or is it inside the tank caused by sediment build-up inside of tank?
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Low-hot-water-pressure.html
http://waterheatertimer.org/How-to-replace-TP-valve.html
http://waterheatertimer.org/images/Water-heater-with-mixing-valve-300.jpg
Jul 04, 2011 | RTO Bradford White M-1-20U6SS 19 Gallon...
What kind of soap do i use and do i use it strait or mix with water i have a 2600 just a hose i think is for the soap
most solutions are sold to be used as is , place the tube from the washer into the cleaning solution as you spray it will be mixed with the spray water . the kind of cleaner depends on what you are cleaning . you can buy cleaner for decks or cars or house etc.
May 15, 2011 | Honda 2500 PSI Gas Pressure Washer
My vacumn has a aweful smell coming from it when in use. Not motor smell.
smells are usually from bacteria. I have seen this before and you can get O.K results by rinsing the machine with cleaning soloution. I like ****-n-span. try to use a cleaner that you like the smell of as it will leave a little of that smell behind. use the vacum in the wet type aplication and use it to **** up the cleaning solution mixed with warm water with about the same mix as you would use to clean a floor. then after the machine fills up let the cleaning solution set in there for 5 to 15 minutes. dump out the cleaning soloution and repeat the process with clean warm water. If it has gotten really bad then you made need to repeat the entire process one or two more times. I also take the pick up hose and clean it with some cleaning solution then rinse outside with a water hose.
Apr 23, 2011 | Rainbow E series Canister Wet/Dry Vacuum
1999 ford focus estate diesel.Windscreen washer bottle has black mildew in it.how do i get it out as it blocks the washer jets.
Remove the windshield washer reservoir and give it a good cleaning with a mixture of 1 part bleach and 3 parts water. You may be able to clean it without removing the reservoir by flushing it throughly and the cleaning it while still on the vehicle with the bleach mix. After it is throughly cleaned put a bleach mix in the reservoir and disconnect the hoses from the spray nozzles and run the washer until the hoses are clean. Use a needle to clean out the nozzles, and the connect the hoses and run the washer until the nozzles are clear. Remove the bleach mix and then fill the reservoir with a commercial windshield washer fluid. I recommend Rain X.
Mar 07, 2010 | 2000 Ford Focus
I have a small amount of oil and water (mayonnaise) in my air filter and car feels sluggish and doesn't start properly
oil is mixing with coolant then only it can happen , replace oil cooler cause oil cooler it is mixing, ,and clean all hose radiator for sludge free.
Jan 21, 2010 | 2001 Ford Focus
Hello Advisors, I need real help and information. I just got a new Maytag washer MVWC 300 VWO. What temperature can I expect in the maschine on the "hot-cycle"? My hot water heater and hot water supply...
The hot water should be as hot as the inlet temp water.
170degrees. There is no internal heater to increase the water temp.
Please check that the hot water supply valve is turned on.
Check the hot water inlet hose is not kinked.
Also - remove the hot water hose and make sure the shipping plug from the hose hookup was removed.
If the hot water supply is on, and there is verified hot water coming from the hose (into a bucket) it will be time for some warranty work - as your mixing valve solenoid (hot side) has failed.
Thanks for using FixYa!!
Jun 05, 2009 | Washing Machines
0491 SECONDARY AIR SYSTEM (BANK 1) FAULT CODE 2001 AUDI A8L
the information is from the air sencoir onthe cat see exhaust. if you have a turbo .check hose from turbo to intercooler and clean check hose from intercooler to inlet manafold and clean if oil water mix found clean and check intercooler you may find oil and water mix
May 01, 2009 | 2006 Audi A4
Oil in hose intercooleer to throttle body 940 turbo
U have a serious turbo seal failure problem.
Mar 01, 2009 | 1992 Volvo 940
Bissell green machine - how to clean
You would need to disasemble the machine to undo the hose. You could try running a mix of water and vinegar to clean out the water lines.
Mar 08, 2008 | Vacuums
No steam
I used the straw to prime the lines and 50/50 mix of vinager and water and it worked perfectly. I then mixed the water container with the same mix and ran it through the system. All works fine now.
Feb 20, 2008 | Black & Decker SV1000-4 SteamBuster Vacuum
Campbell Hausfeld 1,350 Psi Electric Pressure Washer With Auto Detail Kit #PW1350 Logo
23 people viewed this question
Top Campbell Hausfeld Garden Experts
John Trevino
Mike Squire
Are you a Campbell Hausfeld Garden Expert? Answer questions, earn points and help others
