Question about Dehumidifiers
What does the snowflake symbol on a Superclima dehumidifier mean?
HE70ER-L Are there any recalls on this Haier Dehumidifier model?
Results
Dehumidifier Recalls - ConsumerAffairs.com
https://www.consumeraffairs.com/dehumidifier-recalls
  1. Cached
The recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission (CPSC). December 30, 2009 LG Electronics is recalling about 98,000 portable dehumidifiers. The power connector for the dehumidifiers compressor can short circuit, posing fire and burn hazards to consumers.
Humidifiers & Dehumidifiers Recall List by WeMakeItSafer
wemakeitsafer.com > ... > Home & Garden > Temperature & Humidity Control
  1. Cached
  2. Similar
Danby, De'Longhi, Fedders, Fellini, Frigidaire, Gree, Kenmore, Norpole, Premiere, Seabreeze, SoleusAir and SuperClima Dehumidifiers. A recall was issued on 2013-09-12 due to a potential fire and burn hazard.
Dehumidifier Recall: How to Find Out if it Affects You
learn.compactappliance.com > A/C & Heating
  1. Cached
  2. Similar
Jun 12, 2014 - How to Find Out if Your Dehumidifier Was Recalled. ... Many popular brands known for having high quality dehumidifiers such as Danby, Frigidaire, and Soleus had models affected by this recall. ... Brands have taken different approaches to how they have responded to the Gree dehumidifier ...
Dehumidifiers recalled after overheating, fires - USA Today
www.usatoday.com/story/money/business/2014/.../dehumidifiers-recalled.../9145635/
  1. Cached
  2. Similar
May 15, 2014 - Appliance manufacturer Gree has issued another recall for a line of its ... .cpsc.gov/en/Recalls/2014/Gree-Reannounces-Dehumidifier-Recall.
Public Notices ' Haier America
https://www.haieramerica.com/public-notices
  1. Cached
Product Recalls. The latest public notices can be found here. Recall Date. Haier America Expands Recall of Chest Freezers Due to Fire Hazard, Sunday, May 12 ...
Nov 07, 2016 | Haier Dehumidifiers
I need a manuel for the danby dehumidifier model #DDR557HE. I dont know what the symbols mean
Unfortunately, the model number you listed has been discontinued. But is still supported thru the Danby Consumer help line: 800-263-2629. Contact them regarding your need for the Owner's Manual and they can email you one as an attachment.
I hope this helped you, Susan. Thanks for choosing FixYa.
Aug 03, 2011 | Danby DDR557 Dehumidifier
Stays on fan and wont switch to the water symbol
Did you just empty the container? We have one that sometimes you have to slam it back in to get the red light off. Try to take it out and put it back in. Power it off even if you have to unplug it.
Jan 04, 2011 | Danby DDR586R Dehumidifier
Programming timer
SETTING THE MACHINE TO TURN ON
1. Make sure the dehumidifier is plugged in but turned off.
2. Press the button with the clock symbol below it.
3. Press the up arrow to set how many hours until you want the machine to turn ON. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
4. After you have stopped pressing the arrow buttons the display will return to the original display showing temperature and relative humidity.
5. After the above steps are completed the dehumidifier will turn ON in the number of hours that you have set (programmed).
SETTING THE MACHINE TO TURN OFF
1. Make sure the dehumidifier is plugged in and running. You should hear the fan blowing for sure.
3. Press the up arrow to set how many hours until you want the machine to turn OFF. If you have pressed the button for more hours than you wanted then press the down arrow to lower the number of hours.
5. After the above steps are completed the dehumidifier will turn OFF in the number of hours that you have set (programmed).
Jun 21, 2010 | Danby DDR5009REE Dehumidifier
Have portable a/c with dehumidifier. what is the drain in the middle of the unit for with a dial that shows a water drop and a snowflake, and what is the drain on the very bottom for?
The fully clockwise setting is the coldest (three snowflakes). The ... Water-cooling increases compressor capacity when the weather is very hot. Switch off ... Drain all water from the pump, sea strainer, hoses and water coil in the BD housing ...
Aug 21, 2009 | Fedders Dehumidifiers
What settting - snowflake or sun is used to dehumidify we have no instructions with this old dehumidifier. Thermostat doesn't seem to cut out either
well as far as i know the snowflake is for the winter months and the sun is for the summer at least when i was growing up thats how it was explained to me and who knows that could be wrong but it made sense at the time lol hope that helps ya have a good one
Aug 19, 2009 | Dehumidifiers
Changing from air conditioner to warm air dont have a manual
you will need to open the flap of the remote and press the button on the bottom left hand corner with a triangle, snowflake, raindrop and sun. Note on the top part of the LCD screen will be a sun. This indicates heating. Then set temp and fanspeed.
I take the time to help and answer your question so please rate me
Thankyou
Mat
May 13, 2009 | Comfort-Aire BHD-301 Dehumidifier
Dehumidifiers Logo
306 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
