The solution to the problem of my 3loader sharp CD-Bk190 anytime I power it, it always displays protect
2 Suggested Answers
SOURCE: display says protect
check your low voltage fuses, the protect light up when a overload comes....
Posted on Jan 30, 2009
My Sharp CD-M10000W displays "PROTECTION"
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 06, 2011 | Sharp Multi-System Mini Component System...
I have a sharp cd-sx62v player it displays me protect message as i switched on the power and no other buttons are working so i am not able to play cds, cassete, fm.please help me
Reset the player by pressing ON/STAND BY button and simulatenously press preset << and preset>> buttons of the unit.
This will reset the microprocessor of the player.
Aug 09, 2010 | Sharp Audio Players & Recorders
Sharp CD-BA300 stereo system went into Protect Mode. When I power up all it does is display PROTECT. How do I clear it.
1 suspect speaker defect
2. suspect wiring defect ensure all your wires are connected up properly and your speaker are in good order
3. suspect that the cooler fan may be blocked and the system is overheating. use vacuum cleaner on air vents to remove dust.
4 see specialist as this product maybe defective.
Nov 17, 2009 | Sharp CD-BA300 CD Shelf System
Protect error on model # CD BA200 Sharp Stereo
If you are a technician desolder the Audio amplifier IC,and check if the stereo turn on but with no sound.If the stereo turn on the audio amplifier IC is in short circuit and need to be replaced.
Good luck
Jun 05, 2009 | Sharp CD-BA200 CD Shelf System
PROTECT DESPLAY CAN NOT RESET ON SHARP MODEL CDK7000
protect display on my sharp mini component system, how do i fix this problem
Feb 21, 2009 | Sharp Audio Players & Recorders
PROTECT mode
I have a Sharp cd-c2900 home stereo and a "protect" word came up on the lcd?? The stereo is not working now and olnly shows a "protect" word?? Can you please tell me if there is a reset button some where?? Thanks , "Joel" My Email address>> Jovelopa22002@yahoo.com
Jul 17, 2008 | Sharp CD-C2900 Shelf System
"PROTECT" in Display
Probably your output amp. is worn out
Feb 19, 2008 | Sharp CD-BA300 CD Shelf System
Sharp cd player
Most likely cause could be a blown power amp IC.
Nov 14, 2007 | Sharp Multi-System Mini Component System...
Sharp cd ba150
Most likely cause could be a blown power amp IC. The part number is STK402-040.
Oct 25, 2007 | Sharp CD-BA150 Shelf System
Sharp CD-BA300
An audio output IC may be defective. This set carries two output IC's.
Aug 14, 2007 | Sharp CD-BA300 CD Shelf System
 Grubhead
Grubhead
