Question about Rosewill MNTR |LCD 19' 8MS DVI R912E Monitor
Have "input not supported" box on screen
I have a floating box on my screen that says "input not supported" how can i fix this? it does not show up in safe mode, so i have no clue what is wrong
  • Anonymous May 06, 2009
    I have the same problem until after the graphics card has come online. If I'm just in the BIOS, I have to put up with the annoying, floating box. Since I HAVE an image, the input seems supported to me...
  • 221 Answers
SOURCE: Input Not Supported
You need to go into display settings, click advanced, and then click the monitor tab, and change the hertz setting to 60 HZ
Posted on Aug 07, 2008
Geekman
  • 32281 Answers
SOURCE: FLOATING BOX WITH ATTENTION INPUT NOT SUPPORTED
Your monitor has several different video inputs.
Go to the configuration settings on your monitor and select the video input that matches the video cable from your computer.
Posted on Nov 13, 2008
byteguy
  • 2229 Answers
SOURCE: Input not supported icon shows up
Is there a reset, restore button on the monitor? If so, press it.
If this doesn't solve the problem, start Windows in Safe Mode by pressing on the F8 key as it is booting. When you get the black & white menu, choose safe mode. You should be able to change the resolution to a really generic one (like 600 x 800) here to allow you to start over.
You may have set the refresh rate incorrectly in the display screen, too.
Posted on Jan 30, 2009
frcs68
  • 1605 Answers
SOURCE: Input not support, Acer V193w
if the monitor is DVI conencted to PCI card, the computer will not see the monitor, on boot up, only in the Windows mode.
replace the DVI connecting with a VGA connection on the monitor, if there is no VGA connection on the monitor then you need to get a VGA monitor and connect that to theVGA port on the motherboard connector at the rear of the computer.
Posted on Apr 28, 2009
  • 59 Answers
SOURCE: MY MONITOR IS SHOWING AN INPUT NOT SUPPORTED
Does the monitor work on another computer? does the computer work with another monitor? I the answer is yes to both then here is the most likely solution
you may have the screen resolution and/or the refresh rate set too high on the emachines computer. For Windows XP: Boot the computer and use F8 to get the Safe Mode boot menu. Choose the first Safe Mode and log in,... if you see windows come up then go to display settings and and change the settings to something low like 800x600 and refresh rate of 60hz. Restart the system and you will the display and can make adjustments from there.
If either the monitor does not work on another computer or the computer does not work with another monitor,.. or if you are not able to see windows from in safe mode,.. you may have a more serious problem with the monitor or vid card.
Posted on Feb 08, 2010
Floating box
erm......reduce your graphic card output.
Sep 09, 2009 | Acer AL1916W 19" LCD Monitor
Jan 30, 2009 | Acer X193W LCD Monitor
Nov 12, 2008 | Computers & Internet
Input not Supported
Run in safe mode and try to change the screen resolution to 800x600 and reset your machine.
Oct 27, 2008 | Acer V193w LCD Monitor
INPUT NOT SUPPORTED
Start your Windows in Safe Mode (pressing F8) during boot process and adjust your Display Settings to a lower resolution.... say 1024 x 768. Once fixed, you can play around again increasing the resolution a notch at a time. Fix ya!
Aug 28, 2008 | AOC A15X221 15 in. LCD Television
FLOATING BLOCK
hi, it means, u need to change the input mode i.e pal/ntsc/vga..etc or whatever options avilable in the LCD menu..let me know
Dec 28, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Hi receiving input not supported
This message shows that you are not setting the resolution correctly.
When you are in Windows, click on - Control panel - Display - Setting - Screen Resolution (set yo 1280 x 1024). then click ok.
Your floating box will gone.
I got the same problem and got the solution from rma@rosewill.com.
Hope this will help you.
Ringo
Dec 13, 2007 | Rosewill 19" 12MS DVI R911E LCD Monitor
Input Not Supported?
Try changing the resolution in the game. If that doesn't work change the resolution in 'Control Panel' under 'Display'
Jun 28, 2007 | Acer AL1916W 19" LCD Monitor
How do you remove the on screen display?
Sorry, seems like the cctv hardware does not like the type of monitor your using. How you tried a different display and does that correct the problem?
Jun 24, 2007 | X-10 LM929 19IN LCD 12X10-.294MM SPK BLK
Rosewill MNTR |LCD 19' 8MS DVI R912E Monitor Logo
208 people viewed this question
Top Rosewill Computers & Internet Experts
Ian Ballard
Level 1 Expert
Jim Thurston
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
