Question about First Alert FWS-101 Wireless RF Weather Station Clock Radio
EnviraStation DWS 150
How to stop the Temperature/Humidity alert
2 Suggested Answers
rohdd
  • 283 Answers
SOURCE: Need instruction manual for EnviraStation
Here is a ink for the manual
http://www.simaproducts.com/support/files/FW_101_user_manual.pdf
You will need the free Adobe reader to open the file: http://get.adobe.com/reader/
J
Thanks for using FixYa!! I provide my answer for free as a public service - a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
LtCmdr Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Posted on Mar 06, 2011
Paint will not dry after 14 days it is wet
you did not state what paint, on what surface, what is temperature and humidity.
paint usually do not dry if it is two pack and you used only part a (body of the paint) and did not add any part b (hardener). hardener allow chemical reaction to occur and creates then solid, this type of paint is often used on car bodies, boats, hard wearing flooring and similar surfaces. if this is the case, you need to strip and clean whole area, prepare it again, whip off with weak solution of appropriate solvent mixed with bit of hardener (about 1hardener to 25solvent by volume should be fine) rest it for 48hrs, fine abrade with 120 or 150 paper or screen and then paint again following instructions on the label. this usually involves two parts urethane based paints.
another - it can be oil paint - oil paints,, especially good quality (artist quality), based on linseed or cannabis oil, take up to few years to dry, they drying process is affected as well by humidity and temperature, if temperature drops below 10centigrade (50f) process of drying virtually stops, it will fully stop at about 2 to 4 centigrade (35f - 40f), humidity will greatly affect this process as well, very low humidity (below 10%) and very high humidity (above 80%) will hamper drying process, low by forming impenetrable surface skin and not allowing body of the paint to dry, high by preventing vapour pressure to evaporate.
please provide bit more info and then we may find better advice...
do not hesitate to ask extra - and do not forget to vote...
Apr 21, 2014 | Building Materials
Envirastation model dws 170
Usually it is due to bad batteries or remote is too far away from home unit. Put units next to each other and press the channel button on front of the home unit. It will start a search to find the remote. If it finds it with a temp reading press the channel button again and you should hear a beep. Channel is locked in. If you still do not get a temp reading try changing batteries in both units and try again. Another try is to unplug the home unit and wait several minutes with no batteries in either house unit or remote. Replace batteries in remote then in house unit and plug back into power. Set all settings and see if you get the reading. If not try step one again. Weak batteries will do the same thing as well as remote to far away from unit.
Oct 06, 2013 | Measuring Tools & Sensors
I cannot find the owners manual to hometics envirastation dws-400 weather station, and need to know how to synchronize the outdoor temperature sensor with the indoor station readout (i.e. pressing what...
You must remove the batteries in the base unit, replace them, and it should work properly. You can press the Tx button on the back of the remote unit to verify the RF reception. To ensure it is working properly, place both units next to each other indoors and make sure they read the same temperature.
The manual can be found here. Refer to page 3 for more information.
May 03, 2011 | Health & Beauty
Need instruction manual for EnviraStation DWS-110. Basically cannot get wireless to transmit to inside unit. Have new batteries in both units. Pls advise.
J
Mar 06, 2011 | First Alert FWS-101 Wireless RF Weather...
Outside temp not measuring correctly
I keep the outside unit of our in/out set under a coffee can shaded under a bench; one could argue the aesthetics but shielding it from wind and sun is mandatory otherwise one can get record temps pretty often.
The outside units generally transmit to the receivers only every few minutes to keep battery consumption down so moving them won't necessary gie you an immediate change.
Jul 15, 2009 | La Crosse Radio Controlled Atomic Clock
Auto cutter does not cut automatically
TM 220a and TM 220b should come with auto cutters
You have to unscrew the metal tab under the printer, you will find two sets of DIP switches. upper one is DWS 1 and the lower one is DWS 2. On DWS 2 you need to have jumper #2 ON. this enables or activates the auto cutter on printers. Good luck...
Jun 08, 2009 | Epson TM-U220 Matrix Printer
First Alert FWS-101 Wireless RF Weather Station Clock Radio Logo
73 people viewed this question
Top First Alert Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a First Alert Audio Player and Recorder Expert? Answer questions, earn points and help others
