Question about Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
Pioneer docking station - Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Sony dock not working after iOS 6 update? Just says not an apple compatible product?? Any idea of an update or a fix on the way?
My wife had this problem with iPhone 4S after updating to ios6 on a Sony xdr-ds12ip docking station. Sound would play on iPhone off the docking station, but once it was docked no sound would come through the docking station speakers (docking station radio works fine, as did the iPhone before the iOS update). Fixed it by powering down both the iPhone and the docking station at the mains, gave it 2-3 minutes and then powered on the docking station and then the phone. Placed the iPhone in the docking station and voila the sound comes out of the speakers now.
Sep 29, 2012 | Audio Players & Recorders
My home dock has been damaged. Where can I buy just the docking station?
I have had good success seeking out used items like this on ebay. Give it a try. Usually someone's bought a newer radio and is trying to get rid of accessories he no longer needs.
Jan 06, 2011 | Pioneer XM2go Inno Satellite Radio...
I cannot find a home docking station for my Pioneer Airware radio. Do you have any suggestions other than E-Bay? Thanks.
http://parts.pioneerelectronics.com/part.asp?productNum=XMTSE-XMPIH-01
$53.50 retail from pioneer. Any XM2GO dock should work, there are a few home docks on ebay now. You may need to modify it so it can fit your radio, but the pins are all the same.
Dec 28, 2010 | Pioneer AirWave XM2Go Satellite Radio...
Docking station
typically if it's a complete docking station, it uses your laptop power supply and provides power to your laptop and itself at the same time.
http://www.dell.com/downloads/global/products/latit/en/laptop_latitude_efamily_docking_accessories_brochure.pdf'
according to that brochure the dock is the E series.. and doesnt come with a manual
Dec 11, 2009 | Dell D/Dock Expansion Station Docking...
How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
Fix video?
If your video was working fine before then it might be a corrupted file driver of your docking station. No need to worry with your computer because it is not your computer causes the problem. It is your docking station.
You may try reinstalling your docking station software using the cd that came with it.You need to connect your system to your docking station when reinstalling the software. if the issue persist after installing the software. Please check if your docking station still in warranty and check their part replacement policy.
Keep me posted.
thanks.
Oct 16, 2008 | Computers & Internet
Air ware xm2go
The unit has an internal antenna (that is really poor) that is activated when you unplug the external antenna. This is why you get some signal when you unplug the unit.
I assume the problem is the antenna itself.
My suggesion is that you charge up the unit, take it to a place that sells XM equipment AND has a demo unit working. Be sure to take your docking station with you (it has the plug in for an external antenna). Ask the sales rep to please connect your unit to an external antenna to test your unit as you are trying to determine if your antenna is bad. If it works, you need a new antenna (cable may be cut on the inside or antenna may have water/weather damage). If it does not, then there is an electrical issue inside the unit and the unit itelf will need replacement/repair.
Jul 03, 2008 | Pioneer AirWave XM2Go Satellite Radio...
No ethernet with docking station
It could be the connector on the bottom of your laptop that's creating the problem. Does any other ports work on the docking station when docked?
Jan 14, 2008 | IBM ThinkPad T43 Notebook
Pioneer AirWave XM2Go Satellite Radio Receiver with Home and Car Kit Logo
35 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
