Question about HP S3120N Pavilion Slimline Desktop Computer PC - REFURBISHED
Added 2nd hard drivefrom old computer to my XP but will not work
The hard drive gives me all abbreviated names but will not give me the programs. It tells me that files are missing or corrupted I really would like to get those programs back.
  • Nicolas
    Nicolas May 11, 2010
    Hi!
    If you refer to installed programs on the old disk, i have to dissepoint you. Installed programs cant just be moved.
    Nic
    Scholar:
  • 142 Answers
You will have reinstall all of the programs onto the main drive. Or change back to the original hard drive as the main drive, IE C: drive. mysleuth
Posted on Mar 11, 2009
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Hard drive from my xp computer, added as external hdd to new windows 7 pc, need to get ' permission
umm xp used a completely different kind of hard drive and may not be compatible with the windows 7 environment I gather you might be trying to import the old data from that xp drive and use it on the new machine, correct? what is model number of new computer if this in fact is the case.
May 23, 2012 | HP Omni Computers & Internet
I am giving away my daughter's old computer and want to format the hard drive so everything is gone. I have tried to do so, but keep getting an error message that the volume is in use by another program,...
You cannot format the hard drive while it's in use by the operating system itself.
The best way to reformat the drive is with the XP install CD to fully reinstall the operating system. That will wipe all the settings, programs pictures, documents etc.
If you don't have an XP CD you will need to manually go through the computer and delete everything that you don't want the next owner to see.
Alternatively, you can take out the hard drive and then pass it on and leave it for the next owners to get a hard drive and install an operating system.
Regards.
Jul 16, 2010 | Microsoft Windows XP Home Edition
My computer running xp doesnt see my old comps drives that ran 98
hey man try to install windows xp to solve this problem if this problem is not solved then it should be ur hard disk is higher than the compatible default rate which is may be 30 or 20 GB
Jun 20, 2009 | Seagate Barracuda 7200.7 40 GB Hard Drive
Use second hard drive
The Windows operaring system is on your 1st drive (ie C drive) and if you change it to a slave drive the computer won't work.
You need to set the jumper on the 2nd hard drive as a slave drive and leave the original drive as the master drive expecially if the 2nd drive is on the same IDE controller and cable as the 1st. hard drive.
It doesn't matter if the 2nd drive is set to master or slave if it is on the 2nd controller.
When you boot up you should see both hard drives and can copy files from one drive to another.
Apr 08, 2009 | IBM ThinkPad R40 2681
2nd hard drive wont show up correct
Dear,
!. Explore the Device Manager.
2. Select Disk Management. Check both drives are there.
3. If yes, then format the 2nd drive(you can make single or multiple partition) and give it a name. Now you can use it.
Regards,
Rakesh Kumar
Apr 01, 2009 | Computers & Internet
2nd HDD
Check Computer Management / Disk Management. Windows on Windows XP, Probably the Drive needs formatting first and partitioning before it will visible on My Computer. By Default the new Hard Drive is "Unpartitioned / Unallocated". So acess disk Management to format and partition the Hard Drive.
To access the computer management and disk management and create and partition under disk management, Check Videos for guide :
Nov 10, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Multibooting
nope not if its in vista u would nee dto dual boot dl alll latest drivers software for vista then mosttime it works on older stuff
Oct 14, 2008 | Toshiba Satellite A135-S2276 Notebook
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
I have a Onetouch Mini 4, operating fine on two computers with Windows XP but couldn't get it working on Windows 7. I plugged it in and it would be recognized but a message would come up saying there were errors and to scan. Tried scanning and not scanning and couldn't get the drive to work. If I tried to open it would give me the "access denied". I couldn't get to a security tab from a folder as none of them were working.
It ended up that I wasn't listed as an owner nor had any permissions so I needed to be added to the device.
Here is what I did -
System, device manager, disk drives, right click on onetouch, properties, volumes, populate, the select on touch volume, properties, security, advanced, change permissions, add, typed in my user name - hit checked names (it fixed the format), then hit ok.
Then make sure you set the permissions for all the users.
Sep 08, 2008 | Computers & Internet
Transferring music
http://docs.info.apple.com/article.html?artnum=60940
Dec 17, 2007 | Apple iPod nano
HP S3120N Pavilion Slimline Desktop Computer PC - REFURBISHED Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
