Question about Bobcat Miller 225 Welder Generator 907209 Or 907210
Miller bobcat oil reset wont reset
The hour meter wont even show up to see how many hour till it needs to be changed
3 Suggested Answers
  • 4 Answers
SOURCE: how to separate the kohler engine from the
The shaft is tapered and will have a bolt in the center, loosen the bolt enough so you can tap on the end of the bolt. This should release the shaft, if not there should be 2 hole that you can thread a bolt into to push the connection apart.
Posted on Jun 26, 2011
  • 1212 Answers
SOURCE: miller bobcat on propane surges when turned to idle
It might be missing a stabilizing spring on the the throttle shaft to eliminate accumulated play in the components.
Otherwise if no smell of leaking LP is noted, there may be a small vacuum leak in the induction system- can be found with carb cleaner on an idling engine- the area of such a leak when sprayed will smooth out the idle and speed it up momentarily.
If you do smell LP, the regulator likely needs repair or a hose needs replacement..
Posted on Sep 25, 2012
Miller bobcat on propane surges when turned to idle
Sep 14, 2012 | Bobcat Miller 250 Welder Generator 907212...
Miller gasoline tank leaking from meter
Depending on machine model and sn you need to order the fuel gauge repair kit from a distributor. It will have all of the parts needed and instructions on the removal and installation of the new part. This is a commom problem that we are seeing with the Bobcat and Trailblazers. I can drop ship the part from Miller to you if needed. Feel free to contact me at (803) 609-8518 William Scott.
Jun 12, 2012 | Bobcat Miller 225 Welder Generator 907209...
Why is the maintenance light on in my miller 250 bobcat
The maintenance light is probably on because of low oil pressure. Check the level of oil and top it off.
You may also want to check your Air Filter, Fuel Filter, Spark Arrestor, and Fuses.
Here is the manual for your Miller 250 Bobcat:
http://www.millerwelds.com/om/o4419m_mil.pdf
May 21, 2011 | Miller Welding Tools
We lost the manual and can't find the hours of usage on the miller 250 bobcat serial #LH005560.Where would we find it on the machine?
Hour Meter: With engine off, place Engine
Control switch in Run/Idle position to view engine
hours. Meter is located on the front panel in the top right corner.
For more help see page 23 of this document:
May 09, 2011 | Computers & Internet
What does the code on my miller trailblazer 302,004 mean?
Hi:
That's not a code, 004 means the working hours left before the next oil change.
The display always start at 100 and count down all the way to zero.
If you don't change the oil and reset the count down you will start seeing negative numbers, meaning that oil change is due.
To reset the counter once you change the oil do the following:
Cycle engine control switch from the Run/Idle to Run position 3 times.
If this was useful to you, please vote. Thank you..
Mar 23, 2011 | Miller Trailblazer 302 Welder Generator...
Hi i just replace a new lamp for my panasonic but the message on the screen still show u need the reset the lamp hour meter ! please show me how to reset the lamp hour meter
Be sure the power cord is plugged into a properly grounded wall outlet. Then, press the POWER button on the projection display or the remote control to turn the unit on.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen will indicate that the lamp has been reset!
NOTE: When lamp time reset is finished, the LAMP indicator goes out!
Tom Miller
Broadcast Eng
Mar 04, 2011 | Panasonic Televison & Video
Bobcat 225 does not produce ac current 110 or 220?
Probably you need to act the braker, put the idle at max (pull throtle) and let it run for a minute, that will reset the braker.
Dec 03, 2010 | Bobcat Miller 225 Welder Generator 907209...
Miller bobcat 250 welder with kohler lp gas engine won't idle properly any adjustments for air/fuel mix?
Make sure that the idle is set at 40Hz. You do this by placing a frequncy meter on one of the 120Vac outlets. If frequency is low, the engine will run rough at idle. There is a 3/8 nut next to carberator that needs to be turned to the right to increase the idle speed.
May 13, 2009 | Miller Welding Tools
Miller bobcat 225g plus welding problem
If the idle is not working, then it is either you idle solenoid attached to the carberator or your idle board is bad. If you apply 12Vdc to the idle solenoid is should move, if not then the solenoid is shot, no good. If it works then you idle board is bad. Also, check to see if you are 60Hertz by measuring at the outlet with a frequency meter. I recommend a Fluke meter. You should have 120Vac and 60HZ at the outlet. If the frequency is low then your engine speed needs to be increased. The idle solenoid could be causing all these problems.
May 06, 2009 | Miller Welding Tools
Bobcat Miller  225 Welder Generator 907209 Or 907210 Logo
29 people viewed this question
Top Bobcat Welding Tools Experts
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Timllfixit
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
