Question about Kenmore Dryers
I need the schematic for my dryer series 80. Model number 11062822101 A night light bulb accidentally fell in the vent hole, when I pulled out the lint screen to clean it off. My dryer opens in the front, but the lint screen is on the top. I need to get it out, so I can use my dryer. I can't see it when I look in the hole. I have already tried chewing gum on the end of a wire. Do you have any suggestions on how I can get it out.
  • 686 Answers
Lift your lint lid and remove the 2 screws you see then pry the top up at the edges with a wide flat screw driver. If you have a rear cover remove it then remove the 3 crews that hold your lint catcher assembly to the blower housing and you should find your bulb
Posted on Mar 12, 2009
Light inside dryer does not light up.
Your bulb has burnt out. Go to appliancepartspros.com put in your model number, in schematics on left side of page select #5 tumbler, bulb is part #7 cost $5.60. easy to replace, you just have to remove lens cover and replace bulb.
Aug 27, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Belt tension part. it fell off and i need to know where it goes on the dryer. Kenmore 80 series gas dryer.
The bracket goes into holes on the floor beneath the motor pulley and looks like the picture of whirlpool in the link below when properly mounted:
http://www.applianceaid.com/images/belt-config.JPG
Oct 29, 2009 | Kenmore 62602 Electric Dryer
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Can't find the lint trap
There must be two vents going into the interior of the dryer, one is the intake (where the hot air comes from), the other is the outtake (where the lint trap must be). Locate the two vents and see if one of them has anything removable near it (or if the vent itself has finger holes or something that you can grab and pull or slide it open).
Mar 22, 2009 | Kenmore 24902 Top Load Washer
Knemore 80 series dryer won't start every time
Go to www.repairclinic.com and enter your model number and it will show you all your parts, but I suggest you change your thermostats and basically have the dryer cleaned out of possible lint build up on the interior
Mar 20, 2009 | Kenmore Dryers
Kenmore 80 series Dryer: Door Light stays on and wont start
Mar 05, 2009 | Kenmore 800 7982 Dryer
Something in vent
id screen is on top remove the 2 screws under screen lid remove back cover ..remove the 4 screws holding bottom portion of screen housing over blower pull out and clean ..if screen is in door remove bottom cover (clips top edge press down) remove lint screen remove 2 or 3 screws holding housing to blower
Nov 26, 2008 | Kenmore 62802 Electric Dryer
Push to start switch for whirlpool dryer i need diagram i have four terminals on switch two blk. wires, one tan, and one white withred stripe whirlpool model #11062822101
hi how-to-repair-a-dryer-1.jpg Except for the power cord and the exhaust vent, the components that make up the dryer are contained in a sheet metal box. Each component acts independently of the others, but all are interrelated in some way. There are several different ways to disassemble the cabinet for tests and repairs, depending on the manufacturer and model of the machine. Basic disassembly procedures are simple.
Some knobs may be held to their shafts with setscrews. Unscrew the fasteners and pull the knobs straight out. To get at most parts, however, only remove the back panel. Don't disassemble the rest of the cabinet until you're sure you can't make the tests, replacements, or repairs from the back. If the light in the dryer burns out, remove it from the dryer. You may need to remove retaining screws and panels to access it. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the
Step 2: To remove the lower front panel, pull it away from the bottom of the cabinet. Lift the lower panel up and away. Remove the springs under each side of the lower panel.
Step 3: To remove the top panel, wedge a stiff-bladed putty knife under the rim of the top and pry the top off. The putty knife helps release several spring fasteners at the top of the cabinet sides and front.
Step 4: To remove the dryer's control panel, remove the screws that hold it to the cabinet top or front. These screws may be under a piece of metal or plastic trim; pry off or unscrew the trim. Most knobs are friction-fit; pull them straight out.
Caution: When testing or repairing the electrical parts of a gas dryer, remember that the dryer is hooked to a gas pipe. Turn off the shutoff valve on the supply pipe before disconnecting the gas supply line or moving the dryer and before doing any electrical work.
Sep 13, 2008 | Dryers
Dryers Logo
91 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
