By Ranny - usenet poster
Anyone got a faint idea of what A/Rose is, I've heard that its a network "thing"
anyways its causing me to get problems on bootup.
I'm using an A4000T w/CV64-3D+SD and 22MB ram, I do have an Ariadne connected to a 10MB cable
modem, could that be causing the trouble?
I used the plain 7.5.1 install disks and altough it took some time, I did not receive
errors...
All hints welcome!
.Thomas Hansen
Solution #1
posted on Aug 02, 2007
Bouncy - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
(Thomas Hansen) schrieb:
Yeah. Here is, why: A/ROSE=Apple Realtime Operating System Environment
It was thought to use old NuBus-Ethernet-cards with some processors and
their driver soft. So, the only thing, you can do with it: *DELETE*
Maybe this makes it heavier.
That's, because it could *install* it without problems. The use of that
thing causes problems...
CU
Peter
__
,/__ /\/\/ __/--/__ ___ \/\ \/ / __/ / \,
| / // // \ \ | | / \ / _// /\ \ | / |
`/ // // /\/\ \ ????\| | |\ \/\ \/ / ????\ ????\ |\ \'dna
Somewhere in time
CU
Peter
__
Somewhere in time
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Odud - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Thomas Hansen (mailto:) wrote 23-Sep-97 13:36:23 in
comp.sys.amiga.emulations about "SS problem with System 7.5.1 A/Rose" \r
A\Rose is a exstension that "mounts" NuBus cards on MacLC and other Macs
with a nuBus slot. You will *NOT* need this extension in ANY Emulator.
MultiVision Broadcast Productions - SWEDEN
Anders Johansson [ Amiga 4000T 040, 20 Mb RAM ]
[ CV64/3D, A2091, GVP A4008 ]
# [ IBM 14" , Apple 21" Color ]
# [ IBM 35oMB SCSI IBM 12oMB ]
[ Toshiba 3.5x CD-ROM ]
hem.passagen.se/studiox [ Yamaha CDR-102 ]
Solution #3
man1 - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Richard Leese (mailto:) wrote 23-Sep-97 14:33:04 in
comp.sys.amiga.emulations about "Re: SS problem with System 7.5.1 A/Rose" \r
Why dont try "Spacebar" like normal pepole - Then you will get a Extension
Manager (
Manager (
Solution #4
Cato - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
: : Anyone got a faint idea of what A/Rose is, I've heard that its a network "thing"
I remember it being called something like "Apple Real-time Operating
System Extension" and it seems like I haven't seen it included since
7.5(.0), so it's probably not necessary to run SS emulation...
barefoot
barefoot
Solution #5
paulrmc - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
: anyways its causing me to get problems on bootup.
Yeh, just disable extensions on boot, with the shift key and when it
boots up with no problems disable the a/rose extension. All should
then work fine.
||Richard Ryder Leese, Tel : +44 (0)113 233 3872||
||Deptartment of Physics And Astronomy, Fax : +44 (0)113 233 3900||
||University Of Leeds, ||
||Leeds, LS2 9JT email: ||
then work fine.
Can you Help with these Modems problems?
Repair Service
Find Modem Repairman Near You:
