Question about Konica Minolta DiALTA Di200 Copier
I have a error code F34 on a Konica Copier can anyone help
Help with a F34 on Konica Copier 1015
  • 145 Answers
Description:
How to clear fuser abnormality codes (F34, F35, F36).
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
Note: If the F code reoccurs after powering the machine ON or following warm-up, contact service immediately.
good lock
Posted on Mar 14, 2009
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
Our Konica #2125 is displaying a F34 error code. what can we do to fix this?
this code for fuser unit but make sure about this code is that's f34-1 or f34-2
anyhow you need to rest this code
Aug 30, 2010 | Office Equipment & Supplies
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
Error code F34 on Konica 1015 copier is there any way to fix without service call?
No...it's a fuser error (low warm up temperature)...It's a blown fuse, or lamp, and the code can only be reset in 'service mode'after fixing the fault
Mar 11, 2009 | Konica Minolta DiALTA Di200 Copier
Konica minolta problem
How to reset an F34, F35, or F36 code.
Solution:
To clear the code, perform the following:
1. Turn the machine OFF.
2. Enter the 25 mode, (turn the machine ON, while pressing the 2 and 5 keys).
3. Select 1: Software Switch Setting.
4. Use the arrows on the LCD to select dipswitch 3-1.
5. Touch the OFF key on the LCD to change the data to 0.
6. Press RETURN.
7. Power the machine OFF/ON to exit the 25 mode.
PLEASE. NOTE;
THIS IS ONLY TO RESET THIS CODE ,IF IT CAN;T BE CLEARED THAN YOU NEED TO Replace the temperature sensor assembly
Nov 29, 2008 | Office Equipment & Supplies
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
good luck
Nov 24, 2008 | Office Equipment & Supplies
Konica 7020 f34-4
need to rest code 25 mode dip switch 3-1 should be 0
hope that help
let me know if you need more help with access
Sep 01, 2008 | Office Equipment & Supplies
Konica 1015
While holding 2 and 5 turn on machine.Press 4 then 7 then p.Press 0 then p.Turn off then on ,this will reset copier if it does not have a fuser problem which is f35.
Aug 01, 2008 | Ricoh 6513 Copier
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
335 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
