Question about Taylor 2008 C713-27 Soft Serve Ice Cream Yogurt Machine, 2 Flavor
Taylor C713, will not freeze the yogurt. The yogurt will come out all "liquidy" What should I do?
4 Suggested Answers
SOURCE: Where can I find a repair man for Taylor Frozen
Call toll free number 1-800-665-1125 or www.dslinc.com and they will tell you who you can get in your area. The name of the company who services Taylor is DSL
Posted on Apr 19, 2010
qasolution
  • 107 Answers
SOURCE: beater overload
if your mix level is low ice cream will freeze in cylinder which in turn will over amp the beater and cause it to trip. Check mix pump and make sure all orings are good.If mix isnt leaking out make sure it is pumping in.
Posted on Apr 19, 2012
jawaidalvi
SOURCE: taylor soft serve trips breaker
COMPRESSOR IS GROUNDED.
Posted on Jul 29, 2012
Taylor ice cream machine model C713-33 no yogurt comes out when the draw handle it pressed. It seems to be flowing backwards. The agitators are turning in the same direction as the working machines
IF your Taylor C713 is pushing the mix back up through the feed tube, the rotation is reversed. That would only happen on a 3 phase machine like yours.
If you've recently unplugged the machine to move it or something, you probably switched the plugs. Try switching them back.
If you need to reverse the rotation:
1. Unplug the machine.
2. Flip the black and white wires on the plug end.
3. Reassemble the plug and plug in the machine. Make sure everything is tight.
Soft Serve Parts C713
Jun 10, 2017 | Taylor Ice Cream Makers
My C713 water cooled yogurt machine keeps locking and only works when cleaned but only for a few hours then it locks again. Does anyone know why?
The temperature of the product is too high. If the product either in the cylinders or the hopper goes above safe temperature for too long the freezer will lock until the product is removed and the unit is properly cleaned. I would guess it's the hopper temperature because I think you would notice if the product that's dispensed is above 40 degrees. Soft Serve Parts C713
Aug 01, 2016 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Why my Taylor yogurt machine not freezing the yogurt. Model number 339 -58
if cooling light is coming on ck to see if chill plate is getting cold after a few minutes , also visually verify that agitator blades are moving mix around and over chill plate
(chill plate is inside round tunnel that mix bars go thru )
Jan 21, 2016 | Taylor Ice Cream Makers
Had a "comp on too long" message on the machine
this is normal if you just started the machine up from room temperature to freeze a batch, just reset it and it should not reappear , if you didn't and it's been running for days then your refrigerant is low or your cooling tubes are blocked with goo
Oct 20, 2015 | Taylor 2008 C713-27 Soft Serve Ice Cream...
Why does machine have 2 cords and 2 cord caps
Because of the amount of energy it requires. It was set up for a non 220V location. Plug each cord set into a different circuit.
Apr 16, 2015 | Taylor Crown C713-27 Soft Serve Ice Cream...
Beater overload on one side
turn the power off and hit the reset buttons about the size of a quarter hole on the back or front panels. turn back on and it should clear if not then you will need to have the beater motor or contactor replaced.
Oct 08, 2014 | Taylor 2008 C713-27 Soft Serve Ice Cream...
I have a Taylor C713 Ice Cream Machine. IT has been working great until a few days ago. We had it in standby overnight and when we came back the next morning, the ice cream in one side was rotten from...
Those are symptoms of the mix refrigeration system being undercharged. You will need a refrigeration technician to add refrigerant.
In Taylor soft serve machines when the left side hopper (standing in front of the machine) is icing up and the right side hopper is not cold enough, the problem is low refrigerant in that system. It takes R134A.
Nov 11, 2013 | Taylor Frozen Yogurt C713 Soft Serve Ice...
Barrel Therm Bad, keeps beeping on right side
Pretty much what it sounds like, the thermometer in the freezing chamber (barrel) died, and you can't operate until it is replaced. Drain all yogurt and clean and unplug. You need to call a technician out; call 800.255.0626 to find out your local service center.
Sep 15, 2012 | Taylor Crown C713-27 Soft Serve Ice Cream...
Taylor 2008 C713-27 Soft Serve Ice Cream Yogurt Machine, 2 Flavor Logo
74 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
