Question about JVC UXG70 Micro Audio System Shelf System
TRAY ERR message and discs wil not play or eject
I own a JVC UX-G70 which is about 1 year old. After turning on recently, the prpblem appeared. Please help.
3 Suggested Answers
  • 905 Answers
SOURCE: DVD TRAY WILL NOT EJECT
it is definately jammed and will need to be taken apart and unjammed safely to avoid dammage to the unit
Posted on Oct 11, 2008
  • 273 Answers
SOURCE: JVC UX S77 my 5 disc cd says
it sounds like the tray has come off the guides a comon problem with kids pushing the tray in rather than pressing the button. if the teeth on the track are ok then it is just a case of opening it up and putting the tray back
Posted on May 16, 2009
MY CD PLAYER IS LOCKED, THE TRAY DOES NOT OPEN. IT IS A JVC MODEL UX-GN6
Hi .
It's so easy! I hope I can help to You.
For unlock the JVC Cd Disc You only have to put Your Machine in OFF mode and press at the same time the STOP and the EJECT bottoms.
For lock the CD player again You have to do the same process but with the machine in ON Position.
All the best from Spain
Jol Macana
Jun 03, 2011 | JVC UX-GN6 120 Watts Micro Component...
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
JVC UX S77 my 5 disc cd says "tray err". It won't open or play.
May 16, 2009 | JVC FS-S77 Micro 5 Disc DVD Audio/Video...
I have a jvc ux-g50 micro compenent system. Radio plays but will not open cd holders to play cds. Displays number (162)can you please help?
I have a jvc ux -g5. All of a sudden when i turn it on the cd tray no 1 ejects by itself and not closes when i push the button. From time to time it dispalys error 162. Addionaly not any cd fuction is corresponded. Any idea for solving the problem?
Dec 04, 2008 | Audio Players & Recorders
I have a jvc th-p7 cinema system. and when i try to open the tray it say's locked. but i dont know how to take it off?????
You can lock the tray and prohibit the unwanted disc ejection.
On the center unit ONLY:
While the system is turned off
• The system turns on and "LOCKED" appears on the display
window.
• If you try to eject the disc, "LOCKED" appears to indicate that
the tray is locked.
To cancel
Carry out the same operation again.
• The system turns on and "UNLOCKED" appears on the display
window.
Nov 27, 2008 | JVC Televison & Video
Oct 11, 2008 | JVC UX-S57 CD Shelf System
CD deck
That means that there is a mechanical error concerning the tray gears
DVDs presumed stuck and the player won't eject
Hi, If you feel comfortable opening the unit, then you may remove the top cover normally held by 2 - 4 screws. The tray should be visible and most units have a locking bar right at the center to hold the discs down. Removing this (2 screws normally, 1 at each end of the bar) would expose fully the tray with the 2 discs on top. Remove the discs and put the locking bar back with the screws. You can test the unit without the top cover. Please be reminded about safety precaution when working with active/live units and laser equipment. Power it up and check if the "mech err" still shows. If not you're set to cover it up, otherwise, your probably better off seeking the services of a qualified technician. This is a generic method which normally should apply to most CD/DVD units. Good luck and kind regards.
Aug 19, 2007 | Onkyo DV-CP702 DVD Player
JVC TH-A5R DVD DIGITAL CINEMA SYSTEM
I found the solution for my DVD player you need to hold source down for 5 seconds which will unlock the disc.
May 04, 2007 | JVC HR-XVC19S DVD Player/VCR
Tray error
I saw on another JVC systems manual that its an error message that shows when the tray isn't fully open due to an obstruction. If you can locate a manual eject button(usualy you'll need to insert some tip into it) it will help you eject the tray and look for any obstructions, anything looking out of the ordinary there. at least that way you'll be able to take your cds out... You can also try disconnecting the system from all power sources for a few days(including an internal battery), maybe the reset will jog it back to working order. If you're out of warranty and know your way around those things, try taking it apart, cleaning as much as you can, and look for anything out of the ordinary, like broken gears or pins, bent parts, a cog, etc. Good luck
Feb 12, 2006 | JVC FS-S77 System
JVC UXG70 Micro Audio System Shelf System Logo
76 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
