Question about Texas Instruments TI-89 Calculator
Can not display the graphs of functions
I go through the procedure given in the manual page 57. On displaying the graph I get the following message on the screen "undefined variable".
How do I solve this.
Thanks.
  • Texas Instru... Master
  • 7,993 Answers
I have a manual in another language than English, so I do no know exactly or remotely what procedure you refer to, but I have recreated an instance where one gets the error you talk about. I give you the picts.Can not display the graphs of functions - 8147bde.jpg When I enter [Diamond][Graph] I get the following message.
The graph independent variable is x by default, yet I entered cos(f). The calculator is expecting a function of x and I give it a function of some as other entity. Hence the error message. On the command line you cannot change the argument of Y1. It is x by default.
Hope it clarifies things.
Posted on Sep 13, 2009
Help with Ti Inspire Cx calculator. It rounds up the coordinates when graphing
Draw the graphs of the functions you are interested in. While the graphs are displayed Press the Menu key. In the drop down window locate the sub menu Settings (number 8 or 9) depending on your calculator
The following screen is displayed with at the top the setting Float.
Follow the right pointing arrow on the same line as float and select Float 3 or 4 as on the screen capture that follows
Point to the graph of one of the functions select it then press the menu select option Analyze graph then intersection.
You will be asked to select the second function, then the lower bound and upper bound. As you see on the previous screen capture, the coordinates of the intersection point are given with 3 decimal digits.
Apr 27, 2013 | Office Equipment & Supplies
HELP WITH TI INSPIRE CX calculator
Draw the graphs of the functions you are interested in. While the graphs are displayed Press the Menu key. In the drop down window locate the submenu Settings (number 8 or 9) depending on your calculator
6d8395f7-b10e-4d9e-a7e6-45beadb303a3.jpg76f72147-9dcf-457f-a122-ae70490e2815.jpgThe following screen is displayed with at the top the setting Float.
eb304039-5513-442e-886f-d435de8aa653.jpgFollow the right pointing arrow on the same line as float and select Float 3 or 4 as on the screen capture above.
0c4e79fb-d2eb-4461-821f-87adbd63b387.jpgPoint to the graph of one of the functions select it then press the menu select option Analyze graph then intersection. You will be asked to select the second function, then the lower bound and upper bound. As you see on the previous screen capture, the coordinates of the intersection point are given with 3 decimal digits.
Apr 27, 2013 | Texas Instruments TI-Nspire Graphic...
When I try to graph, I get ERR:INVALID DIM I tried going to PlotsOff and I still can not graph
What happened when you tried going to PlotsOff. Did you actually execute the command?
If you executed that command and cannot graph then for some reason you are feeding lists or matrices as arguments to the functions you want to draw.
By the way are you drawing STATISTICAL GRAPHS or FUNCTION GRAPHS?
If you are drawing statistical graphs and you executed the PlotsOff command, it is normal you will not be able to graph because PlotsOff turns OFF the statistical graphs.
Here are a few things you can do:
If you got the message while trying to draw a graph
  1. Press [2nd][Y=] (STAT PLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
If message popped up while doing something else that involves lists or matrices, the length of lists may be different, or the dimensions of matrices may not be compatible.
To Clear the lists:
  1. Press [2nd][0] (CATALOG)
  2. Press [PGRM] (C) to jump to first command that starts with c.
  3. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  4. Calculator displays Done
  5. Start the new problem.
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Aug 17, 2010 | Texas Instruments TI-84 Plus Silver...
Only graph one function at a time
A) Before drawing function Y1=f(X), R1=F(Theta), (X1=f(T), Y1=f(T))
you should turn the statistical plots OFF.
To turn statistical plots off
  1. Press [2nd][Y=] to open the (STAT PLOT) menu.
  2. Select [4:PlotsOff] and
  3. Press [ENTER].
  5. Restart your graphs.
  6. Adjust the window dimensions if necessary or use the ZOOM function to have all graphs displayed.
B) If you cannot draw more than one function
Usually as soon as you start entering an expression in the Y= editor screen, the = sign is highlighted to ensure the drawing of a function. However, if you have previously used the Transfm application to draw dynamic graphs, it takes over the graphing functionalities from the native OS and you can only draw a single graph.
The reason is that dynamic graphing needs one or two parameters that can be changed during the graphing process and the graph redrawn with a new value of a parameter, and you end up with a family of curves differing one from the other by the values of one parameters. But since the calculator has space for 10 graphs at most, only one function can be highlighted.
To make a long story short, you must uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
  1. Press the [Apps] key.
  2. Scroll down or up to reach the Transfmapplication.
  3. Select it and press [ENTER].
  4. If that application was running you will see a new screen that tells you some thing like
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
    Graphing functionalities will revert to the native OS
Another potential culprit is the Inequalz App. You recognize that Inequalz is runnibg if the [ Y=] editor screen shows tabs at the bottom
To uninstall it, do as for the Transfm and select the option that will unload it from memory.
  1. Press [Apps]
  2. Select [ : Inequalz]
  3. Screen displays Inequal RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Press [2:Quit Inequal]
Mar 18, 2010 | Texas Instruments TI-84 Plus Calculator
The calculator doesnt graph two equation on the graph
  3. Press [ENTER].
To make a long story short, you must Uninstall the Transfrm application from memory. The procedure will not erase it, just kick it out of memory.
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
  1. Press [Apps]
  3. Screen displays INEQUAL RUNNING
  • [1:Continue]
  • [2:Quit Inequal]
  • 3:About]
Mar 17, 2010 | Texas Instruments TI-84 Plus Silver...
Won't graph two functions
A) IF YOU GET AN ERROR MESSAGE,
it might be worthwhile to let us know its contents. If you do get a message ( INVALID DIM) you should turn the statistical plots OFF.
  3. Press [ENTER].
B) IF YOU DO NOT GET AN ERROR MESSAGE
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
Another potential culprit is the Inequalz App. To Uninstall it, do as for the Transfm and select the option that will unload it from memory.
Jan 25, 2010 | Texas Instruments TI-84 Plus Silver...
TI-84 won't graph multiple lines
  3. Press [ENTER].
    • Transfrm App
    • 1:Uninstall
    • 2:Continue
    Press1:Uninstall.
Jan 21, 2010 | Texas Instruments TI-84 Plus Calculator
Graphing Feature error message
This usually happens after the statistical graphs have been used. You should deactivate them. Press [2nd][Y=] (STAT PLOT). Select [4:PlotsOff] [ENTER]. Calculator echoes Done on main screen.
Dec 28, 2009 | Texas Instruments TI-83 Plus Calculator
Graph and trace buttons don't work
If either error occurs when trying to graph a function (not a STAT PLOT), the error can be corrected by turning off the STAT PLOTS. The following steps will turn the STAT PLOTS off, allowing the graph of the function to be displayed.• Press [2nd] [Y=] to access the STAT PLOTS menu.
• Select 4: PlotsOff.
• Press [ENTER].
• Try graphing a function like y = x^4-3x^3+6x-1
Jun 03, 2017 | Texas Instruments TI-84 Plus Calculator
Graphing inequalities
While the graph function menu is on the display press the F3 button to display the graph you want to do. Then press the function key that corresponds to the graph that you want. If you have the manual it explains it on page 117. Kind of hard to explain it here when you can't type the buttons. LOL
Jun 07, 2007 | Casio FX-9750GPlus Calculator
Texas Instruments TI-89 Calculator Logo
167 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
