Question about American Standard 2083.102 Standard Collection Bathtub, Right hand outlet
I have wax with ''dye'' on my white jet tub, and can't get it off. Have tried a hot hair dryer, flat edge razor scraper, iron on cotton, vinegar, bleach, and ''goop''. Any other ideas?
  • 102 Answers
Try denatured alcohol
Posted on Mar 11, 2009
How do you clean the jets in a whirlpool tub? Is there any product to put in water and run jets to clean them?
Put white vinegar in the water and run it through your tub. Fill the tub to it's maximum running capacity, which is normally just above the jets, and pour a gallon of vinegar in the water with it. Let it run with the vinegar for about 20 minutes, then turn it off and let the vinegar sit in the jets for about 30 minutes. Then start up the jets again for about another 10 minutes and drain. Then run plan water through the jets for about 15 minutes, drain and that should do it. I would recommend doing this at least once every 2 months depending on your water type and how often you use the tub.
Feb 13, 2013 | Home
Tip
Tips for Waxing - My Guide to Home Hair Removal
Not everybody has the money to spend going to a beauty salon for all their home hair removal needs. For some people it's also just not that comfortable and they feel shy about it.
Whatever the reason, waxing at home is a good option for longer term hair removal, but it takes a bit more planning and knowledge than simply taking a razor into the shower with you.
Check out my tips below for successful home hair removal.
Here are some of my don'ts:
1. Don't wax just after you've been sunbathing or exposed to any other form of excessive heat.
2. Don't go into a bath, hot tub or any other heated water place for a few hours after you've waxed as your skin can get really sore and the pores are more likely to get exposed to bacteria.
3. Don't wax if you are suffering from any kind of allergies or skin condition. Waxing is a super irritant to the skin and you'll only make it worse.
4. Don't start waxing and half way through read the instructions. Make sure you read them BEFORE you get started.
5. Be careful not to burn yourself. Test the temperature of the wax using the inside of your wrist NOT your leg!
Some do's for waxing:
1. Make sure you pull the wax strip off in the right direction. You smooth the wax strip down in the direction of the hair growth and then pull off the strip in the other direction.
2. Pull the wax strip off in one very quick motion. You should make sure that your movement to remove the wax strip is fast as doing it slowly will not only hurt more but also be ineffective.
3.Once you've waxed an area - don't go back to it even if you've missed a bit as this can really damage the skin and cause friction burns and bruising.
4. Use tweezers to remove any stray hairs that didn't come out with the waxing.
My final advice is that you should start with waxing just your legs and see how it goes. Waxing bikini and under arm areas is even more painful and takes a lot of skill. So start with your legs and if you're confident move on and if not, you can always go to a salon for that.
Good Luck
on Jan 06, 2014 | Health & Beauty
Tip
Removing Crayon or Candle Wax from Carpets and Upholstery
<ul> <li>Firstly scrape as much of the wax from the upholstery with a plastic scraper, try not to rub it deeper into the material. </li></ul> <ul> <li>Place brown paper or other thick absorbent paper (not glazed) on the crayon. Using a clothes iron set to low heat setting, press down on the paper. Be careful or you may melt the upholstery. This will remove the excess wax. Keep checking the paper and replace it as it becomes saturated</li></ul> <ul> <li>Spray some WD40 on a paper towel , cotton wool or cloth and rub this into the stain. Repeat this with more towel until you have removed all the color.</li></ul> <ul> <li>Finally scrub the area with detergent and warm water to remove the WD40 and allow to dry</li></ul>
on May 08, 2011 | Washing Machines
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
I just melted my husbands shirt to my iron!!!!!!!!!! how do i clean this mess off of my iron???
Hi hahn rhonda...
Put your iron in the freezer and then use a scraper to scrap off the shirt when it is frozen.
If that does not work, the reheat your iron to the highest setting, after your iron is hot you can use an old cotton towel to iron backwards on to remove the shirt debris
Please take time to rate me
Aug 11, 2011 | Irons
How to clean lime scale out of iron tank
All you need for this is a cotton cloth and white vinegar, a small amount. And you have to rub with cotton cloth for the limescale. Vinegar will act and the limescale will disappear from here.
If it doesn't help you can mix the vinegar with baking soda and it will be a good start point.
When you have finished to polish and to clean the outside, you can clean your iron from inside. For this you have to put a small amount of vinegar and you have to mix it with water.
You have to switch it on to wait. And press the steam. All the limescale will come out of there.
You see? And your iron is shiny and clean, from inside and from outside as well. .
May 19, 2011 | Tefal Irons
New Cannon towels are soft but totally nonabsorbant.label says 100% cotton 100 %aragon
Wash in cold water, and use fabric softener as well as dryer sheets when drying at low heat on dryer. To hot of water and to hot o drying will cause this.
How to remove melted wax crayon from car upholstery
  • Firstly scrape as much of the wax from the upholstery with a plastic scraper, try not to rub it deeper into the material.
  • Place brown paper or other thick absorbent paper (not glazed) on the crayon. Using a clothes iron set to low heat setting, press down on the paper. Be careful or you may melt the upholstery. This will remove the excess wax. Keep checking the paper and replace it as it becomes saturated
  • Spray some WD40 on a paper towel , cotton wool or cloth and rub this into the stain. Repeat this with more towel until you have removed all the color.
  • Finally scrub the area with detergent and warm water to remove the WD40 and allow to dry
Apr 26, 2011 | Crayola Classic Color Pack Crayons...
My steam iron will not steam. How do I clean it?
Mix (1 to 5 parts) white vinegar in distilled water and pour into the reservoir. Let sit for an hour or so, then pour out through a coffee filter into a container, then pour back into the iron for another hour. At this point, heat the iron and try the steamer function. The vinegar solution will clean deposits from the steam jets, so don't try to iron anything yet. Keep running solution through until sputtering stops. Wash out the reservoir with distilled water, then refill and steam wash the ports several times to remove the vinegar. If you can get it clean, continue to use only distilled water in the iron.
Sep 07, 2009 | Irons
American Standard 2083.102 Standard Collection Bathtub, Right hand outlet Logo
60 people viewed this question
Top American Standard Home Experts
Donni Steen
Mike
john h
Are you an American Standard Home Expert? Answer questions, earn points and help others
