For the VHS tape that is stuck inside of the VCR.You should call a person that repairs and fixes VCR's to have a look and see what the issues is and why the cassette drawer is unable to open up.
Press Service menu button and press drop down button on the Touch panel..Select Service settings . Input login no.2500 and password 2500 using numeric keys.
then select reset cassette failure and click enter key. Then switch OFF the machine and then ON.
Then cassette error code issue will be resolved
Cassette sensor switch inside the machine body. Remove cassette outside and check machine body bottom where cassette is installed. Switch Has been misalignment by unfortunately. Align this two Switch Sensor Then again install cassette. Hope its working.....
The best way I know of is to carefully (after unplugging of course) locat th screws (hint - sometimes they love to hide them under stickers/rubber "feet" etc. - run your finger over the stickers while pressing hard, and you will be able to find a "circular indent where a screw hole is hiding) that allows the main shell/case case to be taken off. Generally this will allow you access to the area where the tape is mounted/tangled. From there, just carefully untangle.
Before re-assembling the VHS machine, take a q-tip with some alcohol or ethanol (non-scented nail polish remover), and lightly rub the mirror-like-surface cylinder (the playing head) inside the machine - all the way around. Dirt can accumulate on this head and will catch the tape to tangle it. This is likely why it got caught in the first place. Continue cleaning the head until the Q-tip shows no more dirt. I also used to clean any place the tape touched in sie the machine in this way (spools, etc, it want around that were obviously metal).
To wind the tape back up onto the cassette, locate the "button" on the side that allows you to flip open the front of the cassette (the hinged part that protects the tape but flips up when inside the machine), flip the front up and keep it lifted (temporary piece of tape, or rubber band arnound the entire cassette - whatever).
Look at the bottom of the tape and you will see a hole centered, and towards the top of the back side. you need to insert something into this hole and apply pressure. While keeping the pressure there, you can manually turn the cassette wheels to wind the tape back on.
This dvd/vcr unit is having a problem with component failure. It is probably in the main power supply section, since the unit shuts down. This can happen in these products due to the qulaity of component use in the product runs. The components usually have 5% to 10% failure rate. Which is usually taken care of by the product warranty. Unfornately this is a common problem with big manufactuers and large production runs. You need to have the unit tested and serviced at a service center. The service center will have all the service information to repair you unit. The Magnavox Customer support telephone is 1-800-605-8453. Tell them the model number of you unit and about the problem with the unit shutting down during use. They will be able to tell how to your unit serviced. I hope this information helps you with your problem.
