Question about Plumbing
Leaking FP4A4106NP faucet - Plumbing
How to repair a Single handle faucet leaking at the spout end of flex hose.
Who is the faucet manufacturer? What is the model of the faucet?
Nov 29, 2014 | Plumbing
How to stop sink leak
Check whether the faucet is leaking or the drainage is leaking.
If the faucet is leaking, you need tools to loosen the faucet to check whether the hoses are leaking or not. If the drainage is leaking, you can tighten the slip nut.
May 04, 2014 | Kohler Model 10430: FortĀ® Single-control...
Freuer faucet leaking
Contact Freuer faucet and get free replacement parts. I was even sent complete unit that I had to install.
Mar 21, 2014 | FREUER Faucets Countertop Sink Mount...
Leaky faucet
Need more info. Is it leaking in between the faucet and hose or the end of the faucet or around the handle of the faucet? If leaking between hose and faucet a little rubber washer will do the trick. If its the faucet it could be inside the faucet. You can buy a new one, or take it apart and take your parts to the local hardware store whom can assist you there. If its around the handle simply tighten screw ontop of handle.
Nov 11, 2012 | Washing Machines
Solaris Model #06544860 leaking under the sink. How do I remove and how do I figure out exactly what is leaking?
The first thing I would do is to locate source of the leak. Look carefully at faucet when it is on and see if you have any water leaking from areator and running back down the underside of spout and leaking around base of faucet, also see if you have any leaks around handle. If the leak is from the areator you can just replace it and not have to remove the faucet. when you check under sink on faucet supply lines make sure they aren't leaking at that point. I would use paper towels or rags to wipe everything dry under faucet and let it set for 1/2 hour then check again. If it.s still dry run some water and use both hot and cold water seperatly,checking underside in between. If you determine that leak is coming from top side and leaking thru. Shut off water supply valves if available if not shut off supply to house, make sure water is off before proceeding. Disconnect supply lines from faucet,Remove retaing nuts on either side of base,and remove washers. Remove faucet and check for any obvious faults. If you think it was leaking around base get a small tub of plumbers putty. Most hardware stores stock it. Remove a golf ball sized portion or larger and knead in your hands until it is warm and pliable. Press into place in faucet base. Continue doing this until it's full. Reinstall plastic or rubber base gasket and put faucet back in place Put washers and retaing nuts back on a tighten till snug. Center faucet where you want it and tighten securely. Scrape off excess putty with knife point and wipe with paper towels till clean. Hook up supply lines and turn water back on. Check for leaks and good luck. Thank you
Nov 27, 2010 | Hansgrohe 06649860 Solaris Single Hole...
Faucet is leaking from the cold water line inside the faucet. it is a danze lazio pull out kitchen faucet
Hello
First shut off water to faucet.There should be a allen screw that holds the faucet together near the top back of the handle,lossen this and pull top off.
Next take some pliers and tighten down the lock nuts to compress the washers,do this gently.
Reassemble,water should stop leaking.
Mar 30, 2010 | Danze D403412 Melrose Single Handle...
I have two leaking bathroom faucets. Hansgrohe 06042. I replaced both faucet valves from Hans part no. 94009000. They BOTH still leak steadily. They worked flawlessly for two years.
where are they leaking from?
if they're leaking from underneath, repace the suply lines [between the valve and faucet]. if if from the faucet itself replace your cartrage[s].
Aug 18, 2009 | Hansgrohe 06042 Tango Widespread Bathroom...
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
