Question about Toshiba Satellite L300D-ST3501 Notebook
Power button is not glowing in toshiba satellite c850
5 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: toshiba satellite c660 motherboard not power
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Sep 05, 2012
maxcarson
  • 7627 Answers
SOURCE: how to turn it off
The obvious answer is go to start menu and shut down. You can always unplug and remove battery. I'm not sure what you question means.
Posted on Nov 06, 2012
SOURCE: My brand new Toshiba SAtellite C850 F31Q screen stays black on startup. What can I do?
Got this from another site, since I had the same problem:
The problem is with the power settings, not the OS or anything else
Here are the fix steps:
1. Turn off your computer
2. Disconnect every wire from it (including power)
3. Disconnect the battery from the bottom of the computer. There will be two tabs labeled 1 and 2.
4. Re-plug in the power wire. (the battery should not be in the computer)
5. Turn on the power. The screen will work. Choose start windows normally. (if you get that screen)
6. Go to Control Panel -> (Mobile PC) -> Power Options -> Under Balanced choose change plan settings
7. Choose Change advanced power settings
8. Find Processor power management and change the minimum processor state from 5% to 100% for each On battery and Plugged in.
9. Click Apply then OK
10. Shut down you computer.
11. Disconnect the power cord.
12. Re-install the battery on the bottom of the laptop, plug in the power cord, and restart the computer. "
Posted on Nov 18, 2012
  • 212 Answers
SOURCE: How to play a DVD on Toshiba Satellite Pro C850
If you know the DVD and the DVD drive is in proper working order, it could mean that the software you are running just may have some problems. Try downloading a copy of VLC (VideoLan Client) this application is free and open source (and no it's not something I created and am just trying to get people to use...it's just something that works great, and completely free) VLC can play almost any video file or DVD that it encounters. If VLC can't play it, I would think it's likely there may be something with your disk or your DVD drive.
Posted on Mar 06, 2013
Toshiba satellite c850 driver for windows 8
http://www.mytoshiba.com.au/support/computers/satellite/pro/c850/pskc9a-00t019/download?os=30
May 26, 2014 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite C850-13E both power lights flashing
verify that you are using a tobisha power adapter that is for this computer. blinkng light are normal associate with wrong voltages
Apr 21, 2014 | Toshiba Satellite C850-13E 15.6-Inch...
My toshiba satellite pro C850 won't stay connected to the internet
Is the other computer win8.1? Did it ever work properly on this one?
Jan 21, 2014 | Computers & Internet
My Toshiba satellite pro c850 wont stay connect to the internet
TRY TO UN INSTALL WIFI DRIVER AND RESTART LAPTOP AND THEN INSTALL DRIVER AFTER RESTARTING THEN RESTART ONCE AGAIN AND CHECK.IF ITS NOT WORKING TRY TO UPDATE BIOS LINK FOLLOWS http://www.mytoshiba.com.au/support/computers/satellite/pro/c850/pskc9a-00t019/download?os=25.WHILE UPDATING BIOS U SHOULD BE CAREFULL BATTREY SHOULD BE ATLEAST 50 % AND UPDATE WITH POWER ADAPTER CABLE CONNECTED.
Jan 12, 2014 | Toshiba Satellite Computers & Internet
How to fix error Oxcoooo21a. on toshiba satellite c850
original from microsoft team
Please Check This KB ( How to troubleshoot a "STOP 0xC000021A" error ) : http://support.microsoft.com/kb/156669?wa=wsignin1.0
Dec 02, 2013 | Toshiba Computers & Internet
How To Enter Bios Setup
When you boot up your laptop the keys to enter the BIOS is displayed briefly.
Try ESC or F1 or ESC then F1 or F2
If these do not work then
You can download the manual from this WEB site to finf the BIOS key.
http://www.manualowl.com/p/Toshiba/Satellite-C850-BT2N11/Manual/166320
May 12, 2013 | Toshiba Satellite C850-BT2N11 Laptop
How to turn it off
Nov 06, 2012 | Toshiba Computers & Internet
Toshiba Satellite L300D-ST3501 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
