Question about Sharp AL 1631 Copier
MX-M350N will not print on Windows Vista
We have this copy machine connected to several laptops in our office, however, it may print one day while another it won't. How can we resolve this issue?
  • 29 Answers
Tell your network person set your copier to a staitc IP it seens that each time you turn on your systems depending on what order the computer go on something in your network is assing differant ip address -- or you haver loose cable or bad wiesless netowk to check this you can ping the ip adress of the copier when it not working to see if the request ( times out )if it does -check the router and wires for a loose cable ---i have not seen to many bad network pcb in sharp copiers but that possible too more likliy its juist a set up problem or loose or bad connection
Posted on Mar 11, 2009
How do I allow laptops in the office to be able to use our main printer Sharp MX-C311
You can install the drivers for that printer on the machine(s) needing to print. See if Windows has a compatible driver built in, if not, try the manufacturers website (find "Support"). Also - connect the machine to the network using a network cable or else over WiFi if that is an option for your office. Some newer printers support WiFi right out of the box. I'm not sure what information you need to connect to the printer manually, but if Windows can "see" the printer, the connection is typically seamless and relatively automatic.
Apr 30, 2014 | Sharp Office Equipment & Supplies
Sharp copier mx-m350n
Custom Settings > Key Operator Settings > (enter access code usually 00000) > Image Send Settings > somewhere under this heading is the Fax setting to control transaction reports
Oct 25, 2013 | Sharp Office Equipment & Supplies
Unable to print double sided on sharp mx-m350n with window 7
I had the same exact problem. Go to control panel>hardware and sound>devices and printers. Right click the printer and select printer properties. Click the configuration tab and make sure the duplex module is checked. This should solve your problem.
Jul 03, 2012 | Sharp Office Equipment & Supplies
Printing Pdfs with graphics, pictures, text on MX 700 from Vista
The problem is with VISTA. & Printer Drivers. Say if it prints on the XP why don't you connect the printer to the XP machine and share it so the Vista machine uses that? may work great. have you got the most up to date version of your printer driver? if not get it from manufacturers web site, and install as administrator.
Feb 15, 2010 | Computers & Internet
How do you put a ip address in a sharp mx-m350n thank you.
Here is a link the administrator manual (http://www.sharp-ro.ro/dyn_pdf/doc-MX-M350N-139.pdf) on page 13 it tells you how to set the IP address.
Jan 22, 2010 | Sharp MX-M350 All-In-One Printer
Vista cannot connect to xp printer
It sounds like your are using your Windows XP computer as the print server, and you are trying to connect your Windows Vista machine to the Windows XP print server. Your Vista machine is trying to download the XP drivers from the Windows XP computer to your Vista machine. This won't work. Windows XP and Vista print drivers are not compatible.
If the printer is truely networked (it has it's own IP address on the network, it has its own ethernet connection). Then instead of trying to map out to this shared printer, add new printer to the Vista machine using Vista drivers for the HP Deskjet 3940. The type of port you would need is a standard TCP/IP port. To get this address, print a settings page from the printer. Look for either a TCP/IP address or IP address on this print out. This is the port address you want to create and then connect to.
May 04, 2009 | HP Computers & Internet
Product key (25-symbols) for windows vista home and student 2007
I am sorry but you have to purchase the MS off ice package from microsoft.  Your product key you are refering to is for the Windows program only.  We cannot provide you with a key as it is considered software piracy.
Dec 28, 2008 | Microsoft Windows Vista Home Premium with...
Need help to connect my dell laptop to imagistics 2500 printer please
it is possible to set this multi-function fax/copy/printer for printing from your laptop. There is an available GDI driver from the manufacturer's website (http://www.oceusa.com) for Windows Vista 64 (exe file). Other than that it should install like any other printer.
Jul 01, 2008 | Computers & Internet
Sharp AL 1631 Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
