Question about Daewoo WM1010CC Microwave Oven
Microwave setting does not warm food - Daewoo WM1010CC Microwave Oven
2 slices of bread wrapped in paper towel microwave set on defrost set 35 seconds caught fire
Microwaves work by friction. They blast water molecules in the food so they move fast, just like rubbing your hands together makes them hot. Some types of microwave in defrost mode actually apply FULL POWER for a short period of time so to make the product warm to the touch. This heat then penetrates down to the core of the food, ensuring full defrost. In your case the heat was sufficient enough to heat the dry paper towel to set it on fire.
Bread is better defrosted on the low power setting as sliced bread is very thin. Items should only be defrosted on the defrost setting that are thick and need to be completely defrosted on the inside. Remember microwaves only penetrate the surface of food, making that hot. Thermal conduction does the rest.
You should never use paper towels in a microwave unless the instructions for doing the food say so. You wouldn't put a paper towel in a gas or electric oven, so don't put them in a microwave.
Feb 18, 2016 | In Microwave Ovens
I have been given a A24003 Akai microwave oven & it's not warming foods up... how do I use it?
Here are some general instructions for akai microwaves http://www.akai.com.ro/Resurse/Produse/Manuale/AM820CRL_MANUAL.pdf and it looks like their microwaves will not function unless the clock is set first, so that would be a good start. However, If you have the power level set to High, and you can microwave a glass of water for 2 mins, yet it still comes out cold, then the microwave itself is faulty and not cost effective to repair. Let me know if you have any further queries on this, and good luck :-)
Jun 25, 2014 | Akai A24003 Silver Countertop Microwave 20...
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Mic.oven takes longer to heat food
The microwave may not be cooking at full power, check the settings. If okay the magnetron is on it's way out and will eventually fail.
Jun 11, 2012 | Emerson MW8168B Microwave Oven
Food warming time
When you use the microwave does it make abnormal sounds or noises? If so it could be the magnetron going out. Or power setting could have gotten set to its lowest setting
Jul 21, 2010 | GE JVM1440 Microwave Oven
GE microwave oven Spacemaker Moldel / will not warm food
the most likley problem is the magnetron has gone bad.but there are a couple of thermal sensor in the cabinet that need to be checked. one of those could be bad as well.
Feb 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Won't warm food and takes long
Chances are the magnetron is failing, or you have a bad connection at the magnetron.
Jan 14, 2010 | LG 1.5 Cu. Ft. Full-Size Microwave - Black
My lg microwave is on but does not warm the foof
either the h.v. diode, h.v. capacitor,thermal switch,or the magnetron tube are faulty
Oct 30, 2009 | Microwave Ovens
Ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Jul 31, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Daewoo WM1010CC Microwave Oven Logo
22 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Ian Summerfield
Ian Summerfield
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
