Question about Kenmore Washing Machines
How to remove the agitator on Kenmore 2125 top loading washer
Buckles on bib overals stuck under agitator base
4 Suggested Answers
  • 71 Answers
SOURCE: Sheet stuck under washer agitator.
remove agitator top remove 7/16 bolt to remove agitator. tub mounting hub may be worn which allows the tub to drop down. the hub is located on the center post below the agitator.
Posted on Dec 20, 2008
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
SOURCE: HOW TO REMOVE AGITATOR ON A HOT POINT WASHER
if anyone is still doing this.. i had a hotpoint model type vbxr1060. It had just a cap on agitator no extra bolts and used two hammers to get underneath the base creating leverage..
Work both hammers in (using the nail puller side) as far as possible towards the center of the agitator on opposing sides and use them to pull up and slightly outwards towards the sides of the basin. When you get it off you will see why this works as the agitator's base has mini clips that grasp the base of the air bell housing. hope this tip helps someone.
Posted on Apr 07, 2009
How do I remove agitor to clean the filter. Our clean clothes have a much lint on them when they come out of the washer
Most agitators in top load washers are push on and hold on tight that way. There is space for you to insert fingers under the base of the agitator. Put fingers of each hand under opposite sides under the bottom, grab tightly, and pull up under control. The agitator should come out. Hope this helps. Unless you have the written instructions in your book that says otherwise. Good luck and let me know if it helps!!!
Apr 18, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Top Loading Washer: sheet trapped under round base plate at bottom of agitator. How can it be released?
The link below provides the detailed instructions in removing the agitator to remove the item underneath. Click on the link.
Agitator Removal
Sep 05, 2011 | Washing Machines
AGITATOR IS WEAK & BAD ODER SOMETIMES IN WASHED TOWELS
To remove the agitator take the top off of it(pry off with a screwdriver) using a socket(1/2 or 7/16 inch) and a long enough extension remove the bolt inside the agitator tube. Grasp the agitator under the base and pull the entire base up. You can then clean under the agitator. Not leaving the lid closed when not in use will help(mildew grows in dark damp places). Promptly removing the clothes when the cycle ends and leaving the lid open is probably the best solution.
Nov 21, 2009 | Kenmore 22422 Top Load Washer
I think something is stuck under the washer basin I don't know how to remove agitator
on the old type you turn the centre top to unscrew it. pull up the agitator and replace the same way
May 09, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
We just purchased a top load Kenmore 800 washer machine. We have washed 2 loads of clothes and Now it has stopped filling up with water. It will not do it to wash or to rinse. We have gone thru the mannual...
8 out of 10 times the hose screens are clogged.  1. Remove the hoses from the back of the machine, but leave them connected to the hose bibs.  2. Remove the screen from the hose (it may be stuck at the back of the machine) (This is where deposits usually build up.) 3. Aim the hoses into the drum or a bucket and turn on the bibs. 4. If you don't have a full flow of water coming out of the hoses you will need to remove the hoses from the bibs and reverse the process. Good Luck.
Feb 23, 2009 | Kenmore 22422 Top Load Washer
Clothes stuck under agitator pan
You'll need to remove the agitator.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 08, 2009 | Washing Machines
Several pieces of clothing stuck under agitator.
you can remove the agitator. there are 3 steps to this. 1.take off the top plastic part of the agitator. 2 remove secondary plastic piece from inside of agitator 3. there will be a 7/16 bolt inside and will be deep so you will need a long extension to reach it. hold the fins of the agitator and remove the bolt with a ratchet. once the bolt is out you will be able to lift the agitator up.
Jan 03, 2009 | Kenmore 22422 Top Load Washer
Dec 20, 2008 | Kenmore 23822 Top Load Washer
Remove the center plastic cover with a little flat scre driver,
then remove six screw size 10 around
lift the round plastic base for you to remove the bedsheet.
VERY important qhe putting back the six screw to tigh them not 1,2,3,4,5,6 clockwise, go 1,3,5,2,4,6. Hope this help
Jul 01, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
236 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
