Need to install new toner cartridge in Canon KC 921 copier
SOURCE: toner not set insert toner message
The problem is with the paper tray not the toner, believe it or not. Take all of the paper out of the tray and then reinsert the paper into the tray. It should then work fine.
Posted on Mar 19, 2008
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
SOURCE: My Canon PC-25 copier is streaking
Toner cartridge is defective - replace it
Posted on Apr 07, 2009
SOURCE: Installing the toner cartridge
release the 'clamshell' and slide it in. I don't know what else to tell you
Posted on Jul 27, 2009
  • 990 Answers
SOURCE: Canon 7130F copier. I just installed a new toner
Hello sir; I believe the problem is te cartridge you purchased is refurbish one, please return to exchange.
Posted on Aug 12, 2009
Error code 093-921
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Mar 02, 2016 | Dell 3130cn Color Laser Printer
PC 921 toner light on. Replaced toner cartridge, light still on: won't function.
You see these machines needs to be kept very well.
1. the machine is not sensoring your toner.
a) need for the machine to be serviced it probably has a lot of spill toner inside.
b) toner empty sensor is not positioned properly.
b) the toner empty sensor is not functioning properly and needs to be changed.
Jul 14, 2011 | Canon PC-921 Black and White Copier
PC 921 toner light on. I just replaced the toner cartridge and the light is still on. Help!
Replace the toner out sensor or position it properly.
You can also remove the connector cable for the sensor while waiting for someone to fix your machine. (that is if you know this cable.
may be the toner is not being detected because it got finished completely so you need to mix the toner by switching the machine ON and OFF several times with some good 20seconds time lapse between ON and OFF
A toner catridge leaked in my Canon PC921. I cleaned it up and installed a new cartridge, but now my copies are dark on one side, light on the other.
on analogue copiers, if You have dark copies, that means that You need to clean optics ( mirrors and lenses - maybe some toner get to them ) or check/clean/replace the fixing film!
Regarding poor copy, clean/vacume/change the transfer roller ( beneath the drum unit - on paper path from drawer/bypass, before fixing unit ).
Hope that helps!
Apr 11, 2011 | Canon PC-921 Black and White Copier
How do i clean my canon pc 921
these isnt toner problem. The toner when is out, gives light pictures.
These is optics problem or drum unit problem.
You need to clean beneath copy glass, clean mirrors on scaner rail assy, and beaneth zoom lens cover.
If the problem still occurs replace drum unit. Beare in mind that you after replacing of drum unit must do initialisation under service mode.
Jul 21, 2010 | Canon PC-920 Black and White Copier
How to install toner cartridge in a Canon 920
On your Canon PC 920, there is a recessed gray latch located on the left side of the machine towards the top front...press upwards on this latch to release the top part of copier (same as removing a misfeed or clearing a paper jam). The copier opens up.....now, located in the top unit, about center, is the drum / toner unit. It has a black plastic handle on it. Grasp this handle and pull towards you...slowly...until it is free of machine (support the rear of the unit with your other hand) Open new cartridge (unit) and install in reverse order (there should be instructions with the new cartridge) The copier has rails that the cartridge mounts on. Another note, before installing....gently shift the cartridge from side to side.....this distributes the toner evenly (again, covered in the installation instructions packed with the cartridge) There is a tab that needs to be removed to allow the toner to get where it needs to go for copying....attatched to this tab is a strip of plastic, pull all the way out. I have a PC 940...it uses the same cartridge.
Mar 24, 2010 | Canon Office Equipment & Supplies
Jul 26, 2009 | Canon Office Equipment & Supplies
Trying to find documentation for the Canon Imagerunner 400S. Need to know how to add toner?
Did you look on the box the toner comes in? Also, when the copier needs toner, the display panel will walk you through the steps of how to install a new toner. The hardest part is getting the toner cartridge OFF. You need to press the front of the developing unit right under the blue cover on the front. The Black piece will push in to release the toner cartridge. Good Luck...
Jul 07, 2009 | Canon imageRUNNER 400S Copier
Cannon phtocopier machine
if the image on one side is not clear it means that : 1) the toner cartridge neds to be replaced or 2) The copier needs servicing by a qualified Tech
Apr 25, 2007 | Canon PC-921 Black and White Copier
k24674
jasbo
jasbo
