Question about Acco Brands Corporation GBC CombBind C12 Binding Machine
Paper won't punch on gbc combbind c12
The handle will move up and down, but it won't punch the paper.
Someone jammed our GBC Ultima 65 laminator and now it won’t turn on. I tried to toggle the circuit switch but it won’t move! What next?
The motor may have overheated and gone into thermal shutdown as a result. Probably either a protective device or the entire motor will have to be replaced.
Dec 08, 2017 | Gbc Office Equipment & Supplies
Swingline 74030 manual hole punch handle is locked down
by locked down I am going to assume you mean it will not go back to the normal postion when it is not making a hole. this can be caused by too many of the scrap pieces of paper that are left from making the hole. clogging the punch area. remove all the excess pieces of paper that may be stuck in the whole punch, then try again, you may have to pry the handle and or push and pull it until it releases. do not use again until the handle moves smoothly, clean the areas around the punch.
Mar 07, 2014 | Swingline 74030 Manual Hole Punch SWI74030
Bindmate GBC has paper stuck
Pull out the papers slowly one by one starting from the page on top. They'll probably rip but it's the only way I've found to get them out (I've tried unscrewing the covers but the thing doesn't pop out). For the next usage only punch a max of 4 pages.
Oct 18, 2013 | Acco Brands Corporation GBC BindMate...
Cannot get the arm all the way up
this can be caused by excess paper stuck in the punch area. clean out all the excess paper, making sure to pay attention to the punch area. gently try to move the handle, it may take several tries to get the handle to move freely, make sure you clean out all excess paper before you use again.
Sep 23, 2013 | Swingline Swi-74650 Three-hole Punch - 3...
My hawaiian breeze 16" fan isn't working properly.
try wedging a paper clip in between to hold the gaurd in place.
Jun 17, 2013 | Cars & Trucks
Replacing starter pull cord on 77 20hp mercury
Remove the starter housing from the top of the motor and see if the spring broke or back wound it's self when the rope broke. If all is well remove the rest of the rope from the spool by feeding it back thru the guide hole the handle rests on. Wind it out and find a hole drilled thru the spool and put a punch thru it to lock the spool in place against the spring pressure. Remove the old cord. If it has a steel hook glued to the anchor end you will need a real mercury part. If it has a knot. your in luck.
Take your new cord and burn one end and roll the cord to a point while it is still molten. Tie your knot and heat it till it is cooked so it won't untie itself. Feed the pointy end thru the spool and out the front of the housing. Tie a knot it it where the handle would go. Gently feed the rope on to the spool when you remove the punch.
You will have more rope than the spring could wind. so untie the end knot and feed it back to the spool and put the cord in the notch of the spool so it won't rub on the housing and wind a few more turns into the spring .
When it has enough pressure to completely wind the cord up. put the punch back in the lock hole and feed the cord out the hole thru the handle and knot it, then cook that knot as well.
Sep 16, 2012 | Boating
I have a New Home XLii and the needle position won't move from left to middle to right.
the machine may need to be serviced to see why the needle position won't
move
Apr 26, 2012 | Sewing Machines
Clutch won't release
Start with inspecting the clutch handle for any obstructions or rust.
Lubricate the clutch cable at the handle.
Follow the cable down and look for and pinching or damage.If you can follow the end of the cable to the actuall clutch mecaniism, inspect the area for clearance.
If you can disconnect the cable from the clutch mecanisim and test the clutch handle to see if the cable moves freely.
Manually try to engange an clucth with the engine off.
If it won't move, time to diassemble the clutch.
Apr 07, 2012 | 1996 Suzuki VS 1400 Intruder
Acco Brands Corporation GBC CombBind C12 Binding Machine Logo
132 people viewed this question
Top Acco Brands Corporation Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Acco Brands Corporation Office Equipment and Supply Expert? Answer questions, earn points and help others
