Question about Lands Phones
How can i reset my panasonic kx-tc2100
No dial tone, cannot hear caller but could be heard by caller.
  • 4 Answers
SOURCE: When i dial and press the talk butto, i still hear a dial tone...please help
Please follow these troubleshooting steps;
Tip 1 of 9
Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, you can conclude that there is nothing wrong with the phone. Consider trying a phone that operates on a different wireless frequency.
Tip 2 of 9
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause static/noise, squealing (similar to fax tones), caller ID disruption and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Tip 3 of 9
Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Tip 4 of 9
To get better reception, try moving the telephone base to higher location. Relocate telephone base near a window if using telephone outside.
Tip 5 of 9
Excessive background noise will cause a speakerphone to fade in and out. Try controlling the background noise by turning off any audio devices near the speakerphone. Also, try to avoid interrupting the person at the other end of the conversation while they are speaking. If background noise cannot be controlled, you should terminate speakerphone operation and return to normal handset mode.
Tip 6 of 9
Disconnect any other equipment that is connected in series with your phone. If you phone begins to perform normally, there is a compatability issue with your other equipment.
Tip 7 of 9
If your phone shares a power outlet with a modem, or if it is plugged in to a shared surge protector, try plugging the phone (or modem/surge protector) in at a different location. If this solves the problem, re-locate your phone or modem farther apart from one another, or use separate surge protectors.
Tip 8 of 9
There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. This is normal radio operation.
Tip 9 of 9
You may have a line problem. To test for a line problem, test your unit at another location such as your neighbor’s or relative’s house. If your unit works at another location, contact your local telephone company
Posted on May 08, 2008
  • 84 Answers
SOURCE: Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Posted on Feb 27, 2009
  • 168 Answers
SOURCE: No tones, just a click when dialing
Try setting it on pulse, then hear it click when you push the number, if it works switch it back and try agian
Posted on Mar 05, 2009
SOURCE: Cannot hear any dial tone, but base works OK - callers get busy s
Headset says ringer off, cannot hear dial tone
Posted on Nov 14, 2009
SOURCE: Panasonic KX-TGA601CB cordless phone Was working
phone says move closer to base
Posted on Jan 28, 2010
Cannot get a dial tone or hear caller on one of the handsets, but can hear it ring and the caller can hear me. The other handset is fine.
try unpluggjng base unit from power supply and then let handset unit reset to relocate the base unit.
Feb 11, 2010 | Panasonic KX-TG5632 Phone
Cannot dial but have dial tone, and they hear me, but I can't hea
I GAVE UP WITH NOT HAVING A PHONE AT HOME THAT WOULD WORK. YUP, I DID IT. I BOUGHT A NEW ONE. NOT ALL THE PROBLEMS ARE FIXED. BUT MOST ARE. AT LEAST I CAN HEAR THE CALLER AND THEY CAN HEAR ME.
Jun 29, 2009 | Panasonic KX-TG5632 Phone
Ringer is turned ,i need to know how to turn it on
here is a download of your manual:
[PDF] KX-TG2343File Format: PDF/Adobe Acrobat - View as HTML
KX-TG2343. Pulse-or-tone dialing capability. The unit is Caller ID compatible. ...... Please use only a Panasonic KX-TCA60, KX-TCA86, KX-TCA88, ..... in accordance with the instructions and limitations specified in this manual. WARNING: ...
service.us.panasonic.com/OPERMANPDF/KXTG2343.PDF
May 23, 2009 | Panasonic KX-TG2343 Cordless Phone
Message reads: "Check tel line"
You can remove your telephone line from the base unit and fix it to stranded telephone unit and hear the dial tone.If it heard then some inductor or else part may be broken inside the base unit due high current surge.If the dial tone didn't heard from the other phone also check for the corroded line cord or modular box fault with the tel line.There should be 30 Volt-50Volt D.C.Voltage at your wire ends.
Rana.rishanranatunga@gmail.com
May 18, 2009 | Panasonic KX-TG1033S Cordless Phone
Mar 05, 2009 | Panasonic Lands Phones
Panasonic cordless phone KX-TG6052
reset the dial mode if it is on tone and you have pulse it will not dial out.
Feb 08, 2008 | Panasonic KX-TG6052B Phone
Cannot call out or answer a call
The only thing I can think of is you may be in the wrong dial mode. If you do not have touch tone service you will hear the tones but it will not connect. Try setting it to pulse and see if you can call out. Check you volume or see if the mute has been set. Have you tried a different phone? you might want to borrow a phone from a neighbor to see if it is a service problem or just your phone.
Feb 01, 2008 | Panasonic KX-TG6021 Cordless Phone
Lands Phones Logo
79 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
