Question about Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
Robo kleen model 2906 parts - Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner
dnewcombe1
  • 1564 Answers
SOURCE: Robo Kleen moves but does not clean
If you can, connect it to the back wash of your pool fiter pump. Just for a few secondds that usually works well.
Posted on Aug 17, 2009
thepatioman
  • 52 Answers
SOURCE: My Robo kleen stop working at the end of last
Sounds like you have found the problem. Change the Black Pack. Not sure the pack is available as a seperate part. Suggest you contact Robo Kleen for that info. http://74.84.137.218/website/manuals/RK01A.pdf
The Pool Tech
Posted on Jul 10, 2010
SOURCE: My Robo Kleen motor is running but the wheels do
There is a plastic gear in the drive motor that has a pin that goes through it and the drive shaft, this pin actually wears a slot in it from going back and forth and stops driving the unit.
You can probably hear the driver motor cycling forward and reverse.
i have photos of a modification to fix this
Posted on Aug 06, 2010
jharwell668
  • 640 Answers
SOURCE: Robo Kleen pool cleaner troublshootong
One thing that you might want to try on these pool cleaners is removing the limit screw on the axle for greater angle of tandem wheels. Make sure your filter bag is not clogged or partially clogged because this cause restrict movement. Check for debris jammed in your drive system (wheels, axles, etc.)
Posted on Oct 07, 2010
  • 155 Answers
SOURCE: We need a motor for
First remove the top vent cover (4 screws) and check to make sure the impeller can rotate.. excess debris can prevent it from turning.
I am not aware there is more than one motor on this unit. It should be a single 24Volt motor.
You can contact the mfg at Smart Pool (Maytronics)
email - mailto:info@maytronicsus.com
But I don't see spare parts listed anywhere.
Local Dealer locator
http://maytronicsus.com/en-us/where_to_buy/store-locator/
Lastly.. you may be able to locate a motor once you have determined this one is indeed bad.. at a local electric motor shop. They can test it.. see if it's repairable or replaceable.
Wish I could help more than this.
Best of Luck
Posted on May 01, 2011
The 2906 motor pump use oil
the oil that comes out is pool water and some thick lube
not sure if its suppose to be dry graphite
but i would not add oil , just dry from pool water
Jun 15, 2014 | Smartpool Dolphin Robo - Kleen Above...
My robo kleen moves around the pool but has no suction so it won't pick up any debris
i had that problem, past year
open the motor check for rust stains on the round magnetic surface
i used a steel or copper brillo pad dry to sand down the surface
careful with those plastic motor screw washers to secure motor
Jul 27, 2012 | Smartpool Dolphin Robo - Kleen Above...
Is there any way I can get a replacement wire for my Robo Kleen? Plug broke off end of wire that goes into power box.
You can try MaytronicsUS to get an answer straight from the manufacturer. If they offer the part you seek they can also refer you to a stocking parts dealer to purchase it.
John
Aug 15, 2010 | Smartpool Dolphin Robo - Kleen Above...
What is the output amps on robo kleen transformer
Here is the users manual for these pool cleaners. You might be able to locate the information you are looking for there in the parts specification manual.
http://www.backyardcitypools.com/Pool-Cleaners-Automatic.htm
Jul 03, 2010 | Smartpool Dolphin Robo - Kleen Above...
Smartpool Dolphin Robo - Kleen Above Ground Robotic Pool Cleaner Logo
416 people viewed this question
Top Smartpool Pool & Spa Experts
Craig Butler
Craig Butler
Robert Plante
Are you a Smartpool Pool and Spa Expert? Answer questions, earn points and help others
