Question about Xerox Phaser 6140v_n Blk18/colour20 Pp - XEROX & VISIONEER - 6140V_N Laser Printer
Phaser 6140 service mode
Reset
Xerox phaser 6140
Hi Anonymous,
I suspect you should have this problem sorted by now.
Looking at the Xerox website says that a replacement printer is available for around £190 that could have worked out cheaper that trying to get this one repaired.
Replacement Xerox 6500
Good Luck.
Jun 17, 2014 | Xerox Phaser Office Equipment & Supplies
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
Is there a service mode on the xerox phaser 6500 ?
To enter Service Diagnostics on Xerox Phaser 6500:
1.turn the printer off ;
2.press and hold both the Up and Down arrows and turn the printer on ;
3.when Service Mode and ESS Diag appear on the display, release the buttons. You will need a Service Menu Map to navigate through the menus, they are quite complicated.
Jul 03, 2013 | Xerox 6500/N Phaser Laser Printer
Reseting a printing module
No you have to replace it otherwise you get bad quality
Jun 19, 2013 | Xerox Phaser 4500 Printer
Stuck toner xerox phaser 6140
I am sorry I can not help you. I am having the same problem with a magenta cartridge (also non Xerox)I tried disassembling but I could not find my way. For the time being I am printing B&W .
the other replies are not very relevant I am afraid.
Feb 16, 2012 | Xerox Phaser 6140v_n Blk18/colour20 Pp -...
Wont copy, displays 09,038,46: 14444
www.support.xerox.com/go/results.asp?...8560MFP...
This is a fault of the inkloader. A broken ink is not tripping the sensor, or it is out of ink.
Turn on printer. When logo starts, press and hold the info and back buttons until it says entering diags.
Go to functions menu, scroll to reset IRC counter,enter, and then exit diags. Printer will boot to ready.
Well when the logo is moving before it centers is when you hold down the back and help buttons and it should reboot in service mode, usually it takes it a second or two to start the process. So you can try that again or go into service mode the way you did before. Once in the service/diagnostic mode you need to scroll to the bottom to the function menu then reset the IRC counter in the sub menu and you should be good to go. You were almost there before. I have to do one today so if I notice anything different than the instructions given to you I will post back but Ive done it several times and everything sounds right.
Master link below. http://webcache.googleusercontent.com/search?q=cache:RP4PhFss0oMJ:www.fixyourownprinter.com/forums/printer/62877+Xerox+Phaser+8560MFP/D+error+09,038,46:+14444&cd=5&hl=en&ct=clnk&gl=nz
Jun 10, 2010 | Xerox Phaser 8560MFP Laser Printer
Xerox Phaser 7300DN Laser - Transfer Unit issue
Hold down Back and Information and turn on the printer. You enter in service mode. Then you can reset CRU counters.
Jun 19, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox printer error
The answer can be found here: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
You must manually reset the Belt Cleaner life after replacing the belt cleaner.
Resetting Belt Cleaner Life
  • Resetting the belt cleaner life is to be performed only if the Belt Cleaner Assembly was defective and or the assembly is replaced before an end of life or near end of life message. Not to extend the life of the assembly. Doing so may cause premature failure of other internal printer components.
  • The printer will prompt the user to reset the life counts if the assembly is replaced after receiving a Replace Belt Cleaner Assembly or Replace Belt Cleaner Assembly Soon message.
note_image33x30.gif    Note: If the main Menu does not appear on the front panel screen and only Replace Belt Cleaner Assembly is displayed, there may be a print job that is either processing or currently printing. Try the following steps to clear the print jobs and reset the Belt Cleaner life:
  1. Press the cancel button several times to flush processing jobs from the printer.
  2. If you do not receive access to the front panel menu by doing this, then power off the printer and disconnect Ethernet, parallel or USB cable from the printer.
  3. Turn the printer back on, and while it is powering up, immediately start pushing the cancel key repeatedly until you receive access to the front panel menu.
  4. If the printer menu appears on the front panel screen, follow the instructions below to reset the Belt Cleaner life if the printer didn't prompt you to reset it:
  1. With Menus highlighted press OK.
  2. Press the Down Arrow and scroll to Supplies Info Menu.
  3. Press OK.
  4. Press the Down Arrow and scroll to Exit at the bottom of the menu tree.
  5. Now scroll up to Reset Belt Cleaner Life
  6. .
  7. Press OK.
  8. Reset Belt Cleaner Life NOW is displayed.
  9. Press OK to reset the belt cleaner life.
Mar 08, 2008 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7300
You need to go to theExecute a NVRAM Reset in Diagnostic Mode sceren and find service diagnostics and Execute a NVRAM Reset. You most likely have some software corruption that needs to be cleared.
Dec 16, 2007 | Xerox Phaser 7300DN Laser Printer
Code 09,038.46:4776 whats wrong
that code indicates most likely you have an ink stick in crooked, a broken ink stick in or added pieces of an ink stick.
That code is showing that you most likely have an ink stick loaded incorrectly or it broke.
Nov 28, 2007 | Xerox Phaser 8500/DN Printer
Xerox Phaser 6140v_n Blk18/colour20 Pp - XEROX & VISIONEER - 6140V_N Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
